One eyed MB
headlight on my 2001 320 coupe. The affected headlight in question, and the fog lamp, are only on one side of the car. My first thought was that the car had been in anaccident but I have seller's assurance, and car-facts report that says
otherwise. I've tried toothpaste, and some stuff made to polish out
scratches from plexiglass. Used much elbow grease in both cases, but even
though it improved slightly (?) it's still noticeable.
If I have to, I'll replace the lenses in both. If so, can only the lens be replaced,
or must the whole headlight be replaced ???
Hoping for good news.
Thanks for any and all help
IF your lenses are bad then you can try a 800 grit wet and dry with water then go higher to 1000 and 1200 grit. Theres lots of kits you can buy that have all the paper you need .
Just type in headlight restore kit in google.
You can also use T-cut to clear the lense. Forget the toothpaste this is just for very lightly misted lenses and doesn't work .
If you're interested in just replacing yours let me know. I'm willing to part ways with mine.
For reference, here's my car before polishing them up.
and after:
using one or all of the methods you've suggested.
If that fails, I'll certainly consider replacing them.
This is a great forum, and I hope I can add something to it once
I've gotten more experience with my MB.
Best Regards, and Merry Christmas
and after:
will give it a try over the weekend. It's made in Germany so perhaps
it's as good as some of the other brands I've heard of; looks simple enough.
If it turns out OK I'll try to post some pictures.
