Are these good for my front shocks?
http://www.ebay.com/itm/OEM-NEW-1984-2004-Steering-Shock-Strut-Damper-for-Mercedes-W124-W202-R129-R170-/310806135410?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3ACLK430&hash=item485d7d4272&vxp=mtr
The steering dampener help control the steering wheel on uneven roads and prevents kickback to your wheel. These seem to go on many CLK's. I am actually currently in the process of exchanging mine due to excessive "pulling" and steering wheels kickback.
KRis
If you mean $200 for all four...good luck. Doubt you will find anything that you will actually want to put on your car. Keep in mind the forces the CLK can exert on these parts...you dont want to go the cheap route.
KRis
http://www.autohausaz.com/search/pro...ock%20Absorber
Also, seeing as you're pretty new to this, make sure you buy two as it says "2 per car".
http://www.ebay.com/itm/KYB-KG4731-Front-Shock-Absorber-Gas-a-Just-Shock-Absorber-/141105499893?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3ACLK430&hash=item20da8b0ef5&vxp=mtr
KYB KG4731 Front Shock Absorber Gas A Just Shock Absorber | eBay
I'm curious though, they dont sell rear shocks on that site? I was searching for them but couldnt find any.
I replaced the shocks on another car and it actually feels rougher, like the shocks are too stiff. They were basic Monroe.
The Bilstiens should work equally well.
Cheers, Gator
Just be careful when installing, I had to do it twice. The hardware order on top goes like this:
large washer > small rubber bushing with nipple up > through the body > large rubber bushing with nipple facing down > large washer > 2 nuts on top.
There were no instructions showing this order, they just expect you to figure it out. I did some searches and then figured this is most logical order, although it seems weird to put the large washer on first, but if you don't, then the small bushing will slip down.
The KYB threads are not the same as original, so DON'T TRY TO RE-USE ORIGINAL NUTS or you will strip the threads. I went to ACE and got slightly larger OD and better grade nuts with the KYB thread that also allow the factory dust caps to go back on properly.
I think I will be looking into sway bars next to improve handling.
