Whats a good, reasonable price oil extractor?
http://www.northerntool.com/shop/too...7974_200007974
http://www.northerntool.com/shop/too...Fct9OgodaVIARQ
You can do it for nothing by getting under the car and doing it the old fashioned way
http://www.princessauto.com/pal/en/M...ctor/8319667.p
Its made by JABSCO (PN 17215-000) and sells for $35 - $40. Comes with a dip stick tube, discharge tube. The pump is self priming pump and chucks into a 1/4" or 3/8" electric drill.
http://www.amazon.com/gp/offer-listi...&condition=new
Works great. I got mine at a local West Marine supply store.
Additionally, because the bottom of the drain hole is a bit higher than the bottom of the oil pan, you never get all the old oil out. In the 90's, when the extraction method became popular, there were many disbelievers (including me) but, after draining from below, there were numerous postings that verified that they were able to extract additional oil with using the pump method.
With the extractor method, it's a lot cleaner and faster, because you can do everything, on a level surface, from the top.
Before pumping the oil, it helps to break any existing vacuum by fully loosening the filter cap. I also find it easier to pour the new oil into the filter opening, before installing the new filter.
