So I am about to put my 19's on and I am not sure what the bolt size of OEM is. (12x2!?!)
The bolts stick out about .5" more on the aftermarket wheels, so I'm not really sure what the size should be when I call up an aftermarket wheel house for bolts. Can anyone help me with these or help me these bolts with matching wheel locks? I'm dying to my these rims on :P
Rob
Rob
your w208 clk takes 12x1.5 bolts... when you order, either order the correct length, or order the longest they have
if its long, you can just cut the bolt... but if its short, then you screwed...
mmgrad,Originally posted by mmgrad
Do you know the size of the nut for the bolt? I just bought a torque wrench but not sure what size of nut to buy. Thanks again.
John
Quote:
Originally posted by JohnAMG
mmgrad,
John
gosh... i don't know the exact size... you can take your tire iron and match it at the auto store...Originally posted by JohnAMG
mmgrad,
John
So you are saying that I should buy 12x1 bolts? because the bolts stick out .5" more on the aftermarket wheels and I dont wanna jack up any of the brake internals.Originally posted by mmgrad
Thanks,
Rob
Quote:
Thanks,
Rob
no no...Originally posted by CLK430ROB
Thanks,
Rob
there are 3 measurement you need when ordering it...
12x1.5 is what you need to get.... I think its read like so... 12mm is the width of the bolt, 1.5 is the tread pattern
the 3rd number you need is the length of the bolt...
so technically, when you buy the bolts, it will say like:
12mm x 1.5 x 1.67" or something like that...
no no...
Ahhh... ok..... now the next question is.. does anyone know the length of the stock bolt then? 12x1.5x ????? Originally posted by mmgrad
no no...
Thanks,
Rob
no no...
no no...
Thanks,
Rob
ExploreMBWorld Fanatic!
Thanks,
Rob
just measure it... the length is measured from the bottom of the bolt head... so basically, measure the part that only has tread on it...Originally posted by CLK430ROB
Thanks,
Rob
Hi all,
Anyone know what is the bolt size for the stock rim? I need to send my aftermarket rim out to fix, so i need to put the stock rim back for temporary drive. I couldn't find my stock bolts and need to order a new sets.
Any help will be appreciates.
