HELP! Can't get into trunk!
Any advice?
KRis
Any advice?
KRis
The rest of the door lock/un-lock fine with the remote and the switch inside the car.
A few weeks ago I began hearing a hissing sounds coming the the right rear of my trunk as well as the lid wouldn't close immediately...I had to wait for the pump to stop hissing to close the lid (make sense?)...the hissing got louder and I meant to investigate it but what ended up happening is one day it just stopped making any noise when I try to open the trunk...and the lid will not pop with the remote or the switch on the console. There is no noise of any kind when i depress the button...makes me believe the pump was shot. However If there is only one central van lock pump then maybe a vacuum connection broke loose or something...I have to find time to crawl in there and take apart the trunk lining to see what exactly is going on.
Any tips? Suggestions?
KRis
It will be easier to work on the liner if you can get it open.
BTW..I always keep one rear seat unlocked for exactly your problem.
KRis
KRis
KRis
Any advice?
KRis
Tried same just locked my only key in the trunk after I disconnected the battery and slammed closed the trunk dooh!
. Trust me this is the worlds safest trunk I had lock smith drilling for 4 hours he never got it open :-)
But got it open with a spare battery connected engine bay lol
Vacuum line is torn straight across. You can see the friction marks on the metal of the trunk where it was rubbing or pinching. Looks like I may have been overpacking the trunk during ski trips and such and put enough pressure on the lining to pinch the vacuum hose.
I think I'm going to try and repair it by using a plastic bendable pvc sleeve from a mountain bike hydraulic brake bleeding kit and twist tie the ends together. Then I will try to epoxy the ends to seal and voids. Hopefully this restored the vacuum and my trunk will pop. I really dont want to have to replace the entire line. Looks like a PITA. And I'm thinking even after repair i'll wrap the ***** out of it with electrical tape an hope it last for another 100000 km.
KRis
I located a 2 inch piece or plastic tubing I had laying around in my bike brake bleed kit and i'm going to try and epoxy it onto the vacuum line ends...its just slightly larger in diameter or the vacuum line so I think it will work...the epoxy should help seal it...i'll secure it with some zip ties at either end as well. I hope to achieve a solid seal this way. Again, replacing the entire line is not my preferred choice as it looks to be a PITA. I'll post a picture tonight.
KRis
