Rear Brake Pads
Old Mar 21, 2014 | 07:06 PM
Hitman0187's Avatar
CLK430
Rear Brake Pads
Does anyone know why one out of the four pads has a notch in it by design? And does it matter which side the notched pad belongs on?
Old Mar 22, 2014 | 06:43 PM
tazdevil1964's Avatar
2001 CLK 320
I think you will find that the notch is for a pad wear sensor to slide into....there is one on the front pad's too.
Old Mar 22, 2014 | 08:58 PM
Serndipity's Avatar
2001 CLK320 Cabrio
You weren't clear if the notch is in the pad material or on the mounting plate.
However, most W208s have 2 break wear sensors, which are located on the left and right front axle brakes and none on the rear.
The exception is the E43 version, which uses 3 wear sensors (e.g. 2 on the front and 1 on rear)
See the WIS .pdf attached in post #3 at http://www.benzworld.org/forums/w208...30-normal.html
If the notch is in the pad material, which is where the sensor fits, check to make sure you have the correct rear brake pads.
PS: The rear pads are very easy DIY change (e.g. remove the one spring retaining pin, remove the spring, push back the pistons and then pull out the old pads). I push the pistons back with the old pads still in, so as not the damage the piston rubber seals. Then install the new pads and reinstall the retaining spring back and pin back in place.
Before you drive off, make sure you first pump the brakes several times, in order to restore the required piston-pad contact pressure.
I've read somewhere, where the early CLKs (e.g. 98-99) rear brakes may differ (e.g. might use 2 retaining pins).
Old Mar 24, 2014 | 12:16 PM
Hitman0187's Avatar
CLK430
they are the same pads, I replaced them already. The ones I took off have a notch in the mounting plate. Its only on one of the four brakes on both the old pads and the new ones as well. Im guessing it doesn't make a difference because no one else even realized its there....
Old Mar 24, 2014 | 12:33 PM
Hitman0187's Avatar
CLK430
I found this link that shows what I am referencing - http://www.autopartsnetwork.com/merc...FUYV7AodTHIAOQ
Old Mar 24, 2014 | 01:44 PM
Serndipity's Avatar
2001 CLK320 Cabrio
Those pads do not have a slot for a wear sensor.
The manufacturer likely uses the same backing plate for bake pads (e.g. where the pad wear would include a slot to hold the sensor) for other models, that do require a rear brake wear sensor.
