Clk430
Old Jun 25, 2014 | 05:07 PM
Bigboylloyd's Avatar
Clk430
Clk430
Looking for performance upgrades for my clk. any thoughts? Exhaust, engine , suspension?
Old Jun 26, 2014 | 09:49 AM
averageclk320's Avatar
2000 CLK320
Do a search and you will find everything you need to know.
Old Jun 26, 2014 | 12:03 PM
Gundo's Avatar
2001 CLK430, 2012 CLS550
AMG air box with green filters for some proven extra horses. I just did mine on my 430 and it is noticeable. Gas mileage improves as well.
Old Jun 26, 2014 | 06:24 PM
beefstallionAMG's Avatar
W208 CLK55 AMG, W203 C32 AMG, W163 M Class Sport
Wheel and tire upgrade. 245's in the rear are pretty puny and have trouble putting down the power.
H&R Springs and Koni yellows are a nice suspension upgrade on these cars. Some people have trouble with camber and have to get camber kits after installing though.
The secondary cats can be removed for a straight pipe for a more aggressive exhaust.
What are you looking to do with the car? Daily driver with better performance?
Old Jun 26, 2014 | 07:50 PM
Clk430
Daily but a sick *** daily driver. I just picked it up from an older lady for 6k. It only had 60 k on it. So I was thinking about putting another 5 or 6k in it. I'm definitely doing wheels, would like to do full exhaust with headers. Maybe a full suspension. Thanks for the info. Any ideas on performance would be helpful.
Old Jun 27, 2014 | 11:49 AM
Josh K's Avatar
Tesla Model S
Headers are a waste of money. The exhaust bottleneck is in the exhaust port of the head itself so without addressing that, you won't see any appreciable gain from just headers. If sound is what you're after, cut out the resonator and take your pick with off the shelf cat-backs.
This car likes suspension upgrades, and as Gundo said, the AMG airbox w/ good filters gives you 15 horses at the wheels. I've dyno tested this.
Canned chip "tunes" are a waste of money unless you have serious mods and pay for a custom tune with datalogging.
Sprintbooster is liked by some on here, but it's a waste of money IMO as well. It just makes the computer think you're flooring the gas before you actually are. Some will tell you it eliminates throttle lag and that mercedes purposely put lag in, yadda yadda yadda. This is BS. It decreases your pedal resolution so the car floors it before you're actually flooring it. That's all. Even says so on their own site.
Kleemann makes a very expensive but effective supercharger or you could go the custom s/c route as I did, but it will certainly exceed the budget you laid out. HPS Gen 1 is not efficient, and gen 2 seems to be very efficient at blowing up motors (do a search).
AMG box, suspension, brakes, lighter wheels. That's most of the real performance you'll get on this car without spending serious dough.
Old Jun 27, 2014 | 12:02 PM
Clk430
Thanks bro!!
Old Jun 27, 2014 | 01:28 PM
How many miles are on the car? I'd be looking into maintenance before doing too many mods.
Make sure the wheel bearings are in spec. They are easily adjusted if there is play. Also check your steering gear bolts for proper torque.
I hate to admit this, but a W208 will never have amazing handling. Recirculating ball will never give the feedback of rack and pinion.
I wish someone made a subframe spacer for the W208. You can slightly overtorque the 4 rear subframe bushings for better rear end feedback as they soften over time.
Old Jun 27, 2014 | 03:05 PM
Clk430
It's only got 6ok. I got it from an older lady that used to it to go back and forth from Va to FL.Its in great shape inside and out. I only paid 6k for it.
