battery/alternator
Old Sep 23, 2014 | 07:08 AM
leeroberts0047's Avatar
clk 200
battery/alternator
hi had a warning light on the dash altrenator/battery tested the alternator giving out over 14 volts put a new battery in and the warning keeps coming up, any ideas??
Old Sep 23, 2014 | 08:06 AM
jerryt's Avatar
SLK250
Voltage regulator ??
Old Sep 23, 2014 | 09:20 AM
clk 200
How would I test that?? Just take it out and check the brushes?
Old Sep 23, 2014 | 10:43 AM
jerryt's Avatar
SLK250
Voltage check for regulator and ripple check for alternator diodes. You could research what the conditions are that turn the light on???
Old Sep 23, 2014 | 02:21 PM
MarcusF's Avatar
2002 CLK430
There are no brushes on the regulator. Being an inexpensive normal wear part, you may want to consider replacing it and seeing if that corrects the issue.
Old Sep 24, 2014 | 11:51 AM
big_mike1979's Avatar
CLK 320 (2001) and 2015 GTR
Funny, it happened to me on Monday morning then it never came back again.
I checked my battery and alternator and they are charging the way its supposed too...Go figure.
Old Oct 6, 2014 | 03:41 AM
clk 200
new alternator and battery and the problem is still the same any ideas??
Old Oct 6, 2014 | 02:05 PM
jonUF02's Avatar
2015 GL550 4matic
I believe the voltage regulator comes with the alternator replacement, it's part of or attached to the alternator.
Old Oct 6, 2014 | 02:18 PM
bobbyjo9's Avatar
02 clk 55, 13 GL 450
Alternator output was tested on the car or on the bench? Alternator could be fine but if you have a problem with the trigger circuit, output would be impacted. Have checked and cleaned your cables and connections?
Old Oct 6, 2014 | 02:25 PM
jerryt's Avatar
SLK250
Alternator can be controled by BCM (Battery/Body control module), SAM (Front or Rear) and or ECU.
On my 2012 it is a LIN controled alternator which is controled by both the rear SAM and the ECU.
Post your vehicle information (Model, year, and VIN) and I will check what makes up the system on that vehicle...
Old Oct 13, 2014 | 06:35 AM
clk 200
problem solved just a 200amp fuse blown, lol money well spent on a new alternator and battery lol live and learn i suppose, just the blower motor problem to fix now
Old Oct 15, 2014 | 06:44 AM
clk 200
any one know where the relay is for the climate control? checked the wiring diagram the climate control power goes through it but cant seem to find where it is on the car, any help??
