01 CLK430 replacing lower control arm
apparently the previous owner hit something pretty hard with the passenger side wheel. The passenger wheel is tilted to the right when the steering wheel is straight. At first I figured this was just the tie rod since I could tell it was the only thing obviously bent. It was replaced with an OEM full tie rod. The wheel alignment improved, but I was still unable to align the tie perfectly. taking a closer look it appears that the lower control arm may also have been slightly bent and is preventing proper alignment.
I have reviewed multiple threats about replacing the control arm. From what I understand I need to compress the spring, remove two bolds, then detach the ball joint?
As far as replacement options the dealer wants $650, Ebay has them going for $120. I have decided to take a chance inbetween and purchase a used one from a junkyard. I would trust that more than a $120 part and I refuse to pay $650 for just a control arm.
