w208 cabrio top won't close
Old Mar 19, 2015 | 04:28 PM
vincent1972's Avatar
clk cabrio w208
hello,
i have a clk cabrio w208 from 2000
the stood still from november till last week.
de battery was dead , i changed it with a new one.
the last week after replacing the battery it was Sunny and i opened the top.
this worked perfect but at the end of the day , i wanna close it and then this happened.
the deck opened , the top fully closes and the the topdeck wouldn't close .
it just stays up.
i hear a click if i stopped pulling the switch inside the car for opening and closing the top .
so i went to close it as written in the instruction manual with the hand.
i hope someone can tell me what the problem is or could be.
and if theres anybody who knows where the microswitches are located that's also welcome .
kind regards
vincent from belgium
Old Mar 19, 2015 | 04:41 PM
GatorMB's Avatar
2002 CLK 55 AMG cabriolet Eurocharged
Hi Vince,
The Hatch is the portion that encloses the top when opening, There is a wiring harness on the passenger hinge that feeds the Bow lock which is the top rear section.
The continuous action of use over the years often damages this part of the harness.
Check this first and follow top operation procedures in the manual like luggage cover closed and rear windows down etc.. and report.
The limit switches are located on their respective cylinders, sounds like bow lock harness to me though.
Its time for some ale
Gator
Old Mar 19, 2015 | 05:07 PM
clk cabrio w208
it does everything like opening windows , opening the hatch , opening the canvastop and then while i open the top the hatch closes.
but when i wanna close the top the hatch does open , the top come out of the trunk en closes but then the hatch wil not come down , it stays up.
do you maybe have a picture or so where the wiring harness is located ?
i ask this because the terms passenger hinge and the bow lock , I really don't know what they are because the english tech terms are a bit hard for me.
kind regards
Old Mar 19, 2015 | 05:40 PM
GatorMB's Avatar
This is a better description:
The wires I am referring to are on the right hand side of the hatch (cover) they are for bow lock. still required for control sequence
Your problem is hatch not closing after top is up or closed. hmmm
limits are located on the right hand (sit in car) cylinder for hatch.
I can find you a photo of both but not real quick.
Old Mar 19, 2015 | 06:04 PM
GatorMB's Avatar
This image is typical from years of use, I just photographed it.
Old Mar 19, 2015 | 06:08 PM
GatorMB's Avatar
The bow cylinder limit is here near the center of the photo, one for each side. you must remove the rear seat and rear side covers to test.
It is time for Ale
Old Mar 19, 2015 | 06:10 PM
clk cabrio w208
what do you mean with it's time for ale?
and how should i test this right?
kind regards
Old Mar 19, 2015 | 06:11 PM
GatorMB's Avatar
If you find one of these back there I will come help
Old Mar 19, 2015 | 06:20 PM
clk cabrio w208
that's gonna be hard i think
Old Mar 19, 2015 | 06:22 PM
GatorMB's Avatar
You can see the see cable in the image, The cables have been repaired before by me after continued use and bend back and forth eventually break or fray.
Down in the crevis of the other photo you can see how tight the cable wraps around the linkage. The limit suspect is here.
It is after 6pm here and I am enjoying some home made Ale.
Sorry mate,
Cheers
Testing of the switch will consist of a ohm meter. 0 ohms or infinite
Old Mar 19, 2015 | 06:31 PM
clk cabrio w208
This is the position if i close the top and it isn't go any further.
oké , i wanna thank you already , here is it 23.30 pm at the moment :-)
Old Mar 19, 2015 | 06:47 PM
GatorMB's Avatar
The system must see the bow open or closed before further action.
The hatch cylinder is only 1 the other is a shock, it is the easiest cylinder limit to test.
The top (canvas) cylinder limits are far worse to test. start with inspection of cabling to hatch cylinder. Located near the hinge photo or the left in your image.
This will be in the trunk which makes things difficult
If you have a helper do a wiggle test of the cables while operating the top switch (caution)
Old Mar 20, 2015 | 03:18 AM
clk cabrio w208
oké , i gonna try this in the weekend
Old Mar 20, 2015 | 03:21 AM
clk cabrio w208
i gonna check the wiring harness , the bow lock and the switch on the hatch cylinder.
is this the right way?
Old Mar 20, 2015 | 04:25 PM
GatorMB's Avatar
yes, I would let wife or friend operate the switch while you wiggle if movement is observed get out of the way.
If one of the limits is bad I do not believe it would have completed that much of the sequence. (be safe)!!!!
Regards
Old Apr 15, 2015 | 05:28 AM
clk cabrio w208
hello again,
i haven't time to check the wiring harness etc because i have a couple fingers that are broken.
but today i tried to open the top.
the windows are opening as i lift the top button and that's it.
the button flashes and there's nothing else happens.
the flashes are 1 each second
grtz
