2003 CLK 320 starting problem
If the problem is that it simply will not start, it may be the CPS. If you're a DIY type, it's a $35 part and can be ordered from AutohausAZ. If you're not a DIY type, the dealer can fix it for a couple of hundred.
Just to note its not the contact pins as such on the relay, you have to remove the plastic cover and check inside the relasy on the small spring contacts.
