c
1...77
2...82
3...76
4...77
5...75
6...158
7...0
8...77
9...0
10...1.5
20...0
21...6
22...0
23...0
24...14.4
40...8
41...5
42...232
43...14
Everything else seems to work just fine. All buttons, blower, heat, etc. A HUGE thanks to anyone who can lend assistance!
Any input/suggestions for a Chicago mechanic would be greatly appreciated!!
5 parts make up an auto AC system: The compressor, condenser, receiver- dryer, expansion valve, and evaporator. The leak could be from any of those subsystems or from the hoses that connect those subsystems. You can take your car to any AC place and have them check for leaks. Once they’ve found the leak, they’ll tell you what needs to be replaced and what they’ll charge. USUALLY, it’s the condenser or a hose. The condenser is the thing that looks like a radiator and sits in front of your radiator. That typically springs a leak when it can no longer take the endless rocks, pebbles and 70 MPH sand blasting that things on the front of cars have to endure. Hoses leak because they’re rubber and will eventually dry out AND they’re subject to motion as the engine rocks back and forth (especially engines with bad motor mounts). If it’s the condenser, and there’s a good chance it is, a new German condenser is about $150 at Autohaus AZ or Pelican. Knockoffs are about $100 and the dealer wants about $300. Naturally, labor is extra.
