320 CLK missing badly
Old Feb 11, 2016 | 03:48 PM
hornal's Avatar
CLK320, convertable
My car started missing badly-lost power on my way home on the freeway and I took to a shop that had done good work before. They said my leaky valve covers had ruined my spark plug wires. I took it home and replaced valve cover gaskets and wires and plugs and still runs as if it plugs are bad, or nor sparks in all cylinders. What next anybody, I hate to take it to another shop and get a wrong diagnostic again
Old Feb 12, 2016 | 12:55 PM
burgca's Avatar
'97 S500 Coupe, 2016 AMG S63 Coupe, 2007 Audi Q7
Did you run a code scan? I would suspect a bad coil pack for a sudden misfire
Old Feb 12, 2016 | 01:33 PM
hornal's Avatar
CLK320, convertable
Will scan this weekend
Thank you burgca, I will rent a scanner this weekend.
Old Oct 19, 2016 | 02:42 AM
00w208vert's Avatar
'00 CLK 320 vert (bordeuax) AMG kit, 18" Chrome AMG's, -Studs winter tire on Chrome 17's, Gucci int.
im having a slight misfire on cylinder 5. did you figure out if it was the coil pack or something different? i would appreciate any help and insight thanks for advice in advance
Old Oct 19, 2016 | 04:33 AM
blackopal's Avatar
2000 S430L, BMW 530i
Hmm, would leaky valve covers really ruin plug leads anyway?
Unless you have a car where the plug holes can fill up with oil then I can't see why the garage would have suggested the valve covers as a culprit
What do others think?
Old Oct 19, 2016 | 12:00 PM
hornal's Avatar
CLK320, convertable
Fixed
After it was all done it was a wire connection at the coil pack and I was misled by two shops that couldn't figure it out. A five minute fix cost me 600.00
Old Oct 20, 2016 | 09:25 AM
burgca's Avatar
Glad you found the source, why this wasn't found by shops is one of the reasons to be able to investigate yourself (forums can help, before you visit ant shop. A scanner would show the misfire on the cylinder which would could be coil, wire, plug, or cylinder. Troubleshooting can be time consuming, but finding the source and fixing it yourself is very satisfying.
Old Jan 27, 2017 | 09:02 PM
Jma77i's Avatar
2000 CLK 320
Question
did you have to use electrical tape or just push in the plug some?
Old Jan 30, 2017 | 04:54 PM
GatorMB's Avatar
2002 CLK 55 AMG cabriolet Eurocharged
Tape could be used on an exposed wire.
Some type of Silicon sealer can be applied to loose connectors on the outer casing.
If the connector is rotten from oil or heat it should be replaced
Old Jan 30, 2017 | 06:07 PM
Jma77i's Avatar
2000 CLK 320
hey thanks gator
