Question about ADR M-Classics
Old Mar 13, 2004 | 01:14 PM
Brian_I.'s Avatar
w211 & w124
I recently put on some 19" ADR M-Classics and I noticed that the front rims stick out a little and the rear wheels are kind of set in a little. I believe the offset on these was +39 and the tires are 235/35 all around. Anyone know if I should get some spacers on the back to bring them flush to the fender or what? I'll try and take pics later to explain what I mean in case you don't understand.
TIA.
Old Mar 13, 2004 | 01:25 PM
Josh K's Avatar
Tesla Model S
Yeah, you can get some spacers. H&R makes nice sets of hubcentric ones.
Old Mar 13, 2004 | 02:54 PM
clkal's Avatar
01' CLK55
i believe 5mm hubcentric spacers will work perfectly =)
Old Mar 13, 2004 | 05:08 PM
nickv's Avatar
Used to be a CLK430
I'm running 10mm in the rear - my wheels are 35mm offset.
Old Mar 13, 2004 | 07:23 PM
waterford5301's Avatar
'02 CLK55 and Hummer H2
I'm not 100% sure, but I think the 5mm spacers are not hubcentric. I think the thinnest hubcentric spacers H&R makes are 10mm. I'm ordering 10mm spacers for the front of mine and 15mm for the rear. I have 19x8.5 with a 44mm offset.
Old Mar 15, 2004 | 03:32 PM
Brian_I.'s Avatar
w211 & w124
Thanks Josh, I'll have to look into it.
I also was thinking 5mm would be perfect.
I wonder why yours are a different offset when we both have the same exact wheels.
Old Mar 15, 2004 | 03:33 PM
Brian_I.'s Avatar
w211 & w124
I'll have to ask the guys at the tire shop about this. I think 10mm might work fine in the rear. I want to make sure that they are hubcentric. Does this mean I will need longer bolts?
TIA.
Old Mar 15, 2004 | 08:07 PM
frappe's Avatar
02 CLK 430 blk/blk
I think in most cases where you put spacers on you will need a set of longer bolts to match the spacers.
Old Mar 16, 2004 | 07:52 PM
Again,
Not 100% sure, but I think the stock bolts will work with a 5mm spacer. Anything longer you will definitely need longer bolts. If you get 10mm spacers get bolts taht are 10mm longer than stock..15mm spacer - 15mm longer....etc.
