Are 2002 Clk430's drive by wire?
Old Aug 18, 2016 | 09:29 PM
exhaustgases's Avatar
LS400
Meaning is the throttle operated electrically? That would also mean the accelerator is a potentiometer and no cables or linkage.
Old Aug 18, 2016 | 11:06 PM
MarcusF's Avatar
2002 CLK430
It is drive by wire, but there is a cable. Pop the hood and you'll see what I mean.
Old Aug 21, 2016 | 09:00 PM
LS400
I am rarely around the car. So is the cable operated by a servo then? And the gas pedal is just a resistor? And thank you for helping MarcusF .
Old Aug 22, 2016 | 03:56 AM
shadenfroh's Avatar
If you open the hood you'll see what MarcusF means.
It is drive by wire, it's just not your typical modern setup. The sensor is not in/around the gas pedal itself, it's in the engine compartment. The gas pedal pulls on a metal wire, which then drives the sensor. You can find it next to your brake fluid reservoir, here's a random picture of it with the throttle wire on the lower side:
