Loose Vacuum Line Causing Rough Idle?
Old Dec 7, 2016 | 07:03 PM
Cyshie's Avatar
CLK320
Hey there, this is a wonderful first post to make, but my CLK320 is currently idling rather roughly as well as shaking at low speeds, this has happened once before but I'd rather not run back to the dealership just for them to tighten a hose back up again.
When the car is running there's an audible hissing noise towards the windshield/headlamp washing fluid container and I just wanted to see if someone might be able to walk me through a hopefully easy fix.
Old Dec 7, 2016 | 07:12 PM
ItalianJoe1's Avatar
2003 CL 600
Check back in that area, there are hoses that run from the rear of the valve covers to just below the throttle body for PCV functions. They get oil on them and degrade, or just get old and hard and crack, and allow air to leak in after the TB and cause the rough running. Get in there and see where exactly the hissing is coming from, you will find a broken hose most likely. Replace it and see if it gets better.
Old Dec 7, 2016 | 09:23 PM
pjw1967's Avatar
2023 GLE3502W, 2024 GLC3002W, 1967 Pontiac GTO 4 sp (sold...sniff)
Amen
Old Dec 8, 2016 | 09:01 AM
burgca's Avatar
'97 S500 Coupe, 2016 AMG S63 Coupe, 2007 Audi Q7
Agree
Old Dec 8, 2016 | 09:44 AM
shadenfroh's Avatar
Originally Posted by Cyshie
...currently idling rather roughly as well as shaking at low speeds...
...there's an audible hissing noise...
I have an irregular knocking in idle, more noticable in R/D. Every few seconds I feel a knock through the seat and the Revs take a slight dip. Have you experienced this?
Mine also has developed quite the hiss around the throttle body. Is yours similar?
