couple maintainance questions
Old Apr 7, 2004 | 01:11 AM
seealkay's Avatar
i don't have the service manual yet so i have couple questions. I just changed my oil to mobile 1 synthetic 2000miles ago. and I want to make sure how long they'll last. im thinking 7000miles? also is the tranny fluid life time or do i need to change it? if so when? my car is at 40400miles right now. thanks for the help.
ps. the more I look at my car the more i felt in love. i want to take good care of my baby
Old Apr 7, 2004 | 01:32 AM
count_schemula's Avatar
1999 M Coupe
I change my Mobil1 and filter around 5000-6000 miles. Or right after I track the car.
This study seems to say that Mobil1 thinks 8000 miles or so or longer with a filter change.
http://neptune.spacebears.com/cars/stories/mobil1.html
A lot of new cars say 15000 miles.
It is the black art. I'm sticking with 5000-6000 miles and synth.
Old Apr 7, 2004 | 01:37 AM
1999 M Coupe
Personally, I'd change the tranny and the rear diff fluid in the 40k to 60k range.
I did mine at 44k. The stuff that came out was evil.
Old Apr 7, 2004 | 07:54 AM
Chappy's Avatar
AMG
I agree about the tranny and rear diff fluid change.
I change my Mobil 1 at 5,000 intervals in the CLK and every 3,000 to 4,000 miles for the dino oil in the CE.
Old Apr 7, 2004 | 08:27 AM
nickv's Avatar
Used to be a CLK430
I change my oil and filter every 3000 miles - don't want to take any chances!
Old Apr 7, 2004 | 12:00 PM
SoCalCLK's Avatar
2017 W205 C43 AMG
5,000 Miles is a good interval for oil changes with Mobil 1. BTW, what grade do you use? I think either 0-30W or 10-30W.
Old Apr 7, 2004 | 12:30 PM
Chappy's Avatar
AMG
Mobil 1 0W40 and Castrol 20W50 in the W124 coupe.
Old Apr 7, 2004 | 05:47 PM
1999 M Coupe
nice link I found in the archives...
http://www.mercedesshop.com/diy_oil_change2.htm
Old Apr 7, 2004 | 06:56 PM
seealkay's Avatar
Im using 5w 20 or 30. i was going to use 0w30 but they didn't have enough for my car. what kind of oil should i change for the rear diff and tranny oil?
Old Apr 7, 2004 | 07:16 PM
Adobe's Avatar
Mercedes does not recommend any of the current Mobil 1 30 weight oils. When Mobil changed these viscosities from a PAQ based oil to a petroleum based oil, they no longer recommended it.
Stick with 0W-40 or 15W-50 Mobil 1.
Some oils which are not recommended:
Mobil 1 Super-Syn 0W-30 SL/SJ/CF A1/B1/A5 9.7 doesn't meet 229.1 nor ACEA A2 or A3
Mobil 1 Super-Syn 5W-30 SL/SJ/CF A1/B1/A5 9.8 doesn't meet 229.1 nor ACEA A2 or A3
Mobil 1 Super-Syn 10W-30 SL/SJ/CF A1/B1/A5 10.1 doesn't meet 229.1 nor ACEA A2 or A3
Old Apr 7, 2004 | 07:21 PM
Adobe's Avatar
My God! That 20 weight oil was invented by Ford to help them reduce their CAFE averages. I'll bet everything I own that real Ford engineers would never use it in their own vehicles.
Go to AutoZone and get 0W-40 Mobil 1 (recommended by both Mercedes and Porsche). It was formulated for European high performance engines and will work in any climate.
Both companies approve Mobil 1 15W-50 as an alternative.
Old Apr 8, 2004 | 01:06 AM
Harkonen's Avatar
My oil was recently changer w/o a topsider
A local Mercedes/BMW mechanic replaced the oil in my CLK430, and drained it through the bottom of the vehicle (traditional method). Is this a problem? Did he jack up my car?
Old Apr 8, 2004 | 01:17 AM
1999 M Coupe
Re: My oil was recently changer w/o a topsider
I'm planning on doing my friend's out the bottom. I level the car while draining, so, is there a design reason why draining out the bottom drains less oil?
Old Apr 8, 2004 | 09:44 AM
face118's Avatar
00' CLK 430
NJ Service Asdvisor
Hi :
Anyone have good recommendation of good MB service advisor in NJ? I live in central NJ and my car need B service soon (in a month) and want to get it done right. I call up German car shop and they quote me $500 up. Is it true? I heard people said around $250 at west coast.
Help!!
Old Apr 8, 2004 | 10:20 AM
lionj's Avatar
Is there any info, link or directions on changing the tranny fluid and the rear diff. fluid, I have never done this and would like to. I have only changed motor oil. thanx in advance
Old Apr 8, 2004 | 11:57 AM
kimber45's Avatar
2001 CLK-430 Black
As for the car manual for an 01 430 CLK, I just downloaded a PDF version from Startecinfo last week. Give me a few days and I will upload it to my website so you can grab it.
For service in NJ, I have delt exclusivly with David Michael Mercedes in Freehold, the service managers name is Chad, I think B Service is 420.00. They always treat me right and luckily my service is still included under warranty which I have until next year.
They have completed about 7k worth of warranty work for me and it seems the car is now almost perfect!
Chad even has rented me a car when they ran out of lenders two weeks ago.
Tell him Robert with the black CLK sent you and im sure he will take good care of you.
I have heard bad things about Ray Catena MB from more then one person.
Old Apr 8, 2004 | 02:02 PM
face118's Avatar
00' CLK 430
NJ Service Advisor
Thanks Kimber45.
Ray Catena gave me hard times since I didn't purchase my ar there, and I also heard a lot of negative about their services.
Freehold MB is kind of far away for me ( an hour drive) but will consider it
Thanks again
Old Apr 8, 2004 | 03:04 PM
1999 M Coupe
I hope to do this on a friend of mine's 430. I'll take pics and so forth when I do.
On my BMW, you pretty much just drain and refill the tranny, note, that I have a manual transmission though.
For the diff, full was the overflow point of the refill opening while the vehicle was level.
One nice tip I heard was, loosen the diff refill plug first. Prevents draining the fluid and then not being able to get the refill open! I was like, that's smooth.
Old Apr 8, 2004 | 09:36 PM
seealkay's Avatar
I have one more B service left in my warrenty. do they change all the oil/tranny/diff fluids? or do they charge money for them? my service is due in 3000miles or 6 months 4 months which ever come first.
Old Apr 9, 2004 | 06:57 AM
Chappy's Avatar
AMG
They will not change the transmission and diff fluids unless requested by you (at your expense).
Old Apr 9, 2004 | 02:28 PM
seealkay's Avatar
how much will tranny and diff oil be? is there choices for good and bad types?
Old Apr 9, 2004 | 02:32 PM
Chappy's Avatar
AMG
I haven't had this service done on my CLK yet....(I'm at just over 11,000 miles). But the transmission service alone on the CE runs $100+
Call you mechanic and ask.
