W208 gearbox issue
Old May 18, 2017 | 12:59 PM
Sparkyg1000's Avatar
Mercedes clk convertible
W208 gearbox issue
Hi all
I'm looking for some help before I burn this clk
I have a 2002 clk 2.3 kompressor. 722.616 gearbox.
Issue is when I'm driving it will select 1-2-3 no issue then when it selects 4th it selects at first then goes into neutral and it revs itself to the limiter. Sometimes I can put gearselector into neutral then back into drive and it will select a gear if not I need to pull over and switch off and start again.
I have changed conductor plate the connector at front. There is no oil in the control module in the foot well. Filter and oil been changed and it's bang on the mark.
No broken spring in the valve body as I was hoping it was that. So ordered the spring and the valve body is different from the one with the broken spring.
Code is read on snap on reader which is 146 inadmissible transmission ratio
I've had it on a star machine and it's the same code discrimination
Help please before I burn the thing
Old May 20, 2017 | 11:43 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W208 forum...
