Fuel pump relay not being activated by control unit
Old Jun 16, 2018 | 02:25 PM
marko69's Avatar
'01 CLK 430 cab, '04 SL500 (230K miles)
I have a crank, but no start condition. I can activate the fuel pump using the DAS activations but it will not activate on normal startup. I had a few
fault codes including the Rollbar and Alarm siren codes. I fixed the Rollbar code. I can't activate the alarm siren with DAS, probably something wrong with it, but I went ahead and coded the PSE control unit to no ATA system, no alarm system, which got rid of the siren alarm code which I thought might be preventing the car from starting. I now have 0 fault codes but I'm still not getting 12vdc from the ME-SFI control unit to activate the fuel pump relay. I do get the 12vdc when activating it with DAS. Any idea's????????????
Old Jun 16, 2018 | 06:45 PM
Serndipity's Avatar
2001 CLK320 Cabrio
Hi Mark,
A faulty CPS sensor, will allow cranking without starting the engine, because the ECU disables both fuel delivery and spark.
Strangely, sometimes you'll get a DTC, sometimes not.
Old Jun 17, 2018 | 11:50 AM
marko69's Avatar
I did try and test the CPS with DAS but it required a socket box and another test set.
This is the part that concerns me. The ECU shows the status of drive authorization as "immobilizer is activated" but it
also shows the immobilizer as "not active". I checked the EIS control unit (the ignition) and it shows everything happy. It
see's the key and data being transmitted and all looks good.
I tried jumping across the fuel pump relay to activate the fuel pump, but the car still would not start. I suppose the ignition coil is
also disabled. I will throw a CPS at it.
Old Jun 17, 2018 | 12:33 PM
cm60k's Avatar
Did you check fuse (#1) in the trunk, it may went a way..!
-;ZAYED;-
Old Jun 17, 2018 | 02:21 PM
marko69's Avatar
I was able to run the fuel pump with the computer and also with a jumper across the relay so fuse #1 is good.
Old Jun 17, 2018 | 05:03 PM
cm60k's Avatar
I see,
What about the starter K40 Relay (in the main fuse module), have to check it, as well as all fuses..?!?
-;ZAYED;-
Old Jun 17, 2018 | 05:53 PM
marko69's Avatar
Starter works great. It'a a crank, no start. All the fuses are good in that fuse box.
Old Jun 17, 2018 | 05:58 PM
cm60k's Avatar
Did you change the CPS recently..?, it's also one of most common start issue..?!?
-;ZAYED;-
Old Jun 17, 2018 | 05:59 PM
cm60k's Avatar
Did you change the CPS recently..?, it's also one of most common starting issue..?!?
-;ZAYED;-
Old Jun 17, 2018 | 06:12 PM
marko69's Avatar
I'll be ordering one tonight and I sure hope that fixes it.
Old Jun 18, 2018 | 02:14 AM
Serndipity's Avatar
2001 CLK320 Cabrio
Mark
Those socket boxes can be very expensive.......the one required to probe the soft top N52 controller is around $2,700 MRSP!
The ECU uses the CPS signal to control the fuel and spark delivery.
I can suggest other methods to see if it's generating a pulse train when the engine cranks, but it requires removing the CPS connector and probing the CPS terminals with a multi-meter, as the engine cranks. You also need to know if the CPS uses magnetic or Hall effect technology (I believe MB uses the later). However, it's easier to just replace the CPS.
IMHO, given the number of forum CPS failure threads, it's a wear and tear item, which probably should be replaced as preventive maintenance.
My CPS bit the dust 5 years ago at around 80,000 miles (e.g. difficulty restarting a warm engine and engine shut downs when stopped at traffic lights).
A Bosch OEM CPS runs around $35 and an easy DIY replacement (took me less than 10 minutes on a M112 engine). The only PITA was access to the CPS on the bell housing. I found using a 1/4" ratchet wrench with a very long extension and E8 torx socket worked well. The socket wasn't magnetized, so I added some bearing grease to prevent loosing the fastening screw. Also, during production, the W208 used 2 different CPS types (e.g. difference being that there were either 1 or 2 locking tabs to squeeze to remove the connector). My CPS pulled right out (sometimes they stick and require more effort).
Old Jun 21, 2018 | 06:33 AM
marko69's Avatar
New Bosch CPS installed, no change, good crank but no start. I checked for spark and I do have it at the spark plug. Fuel pump should come on momentarily when I turn the key to on, but I still don't even get that. I can operate the fuel pump with my DAS computer. There is a youtube video of a guy going thru the drive authorization settings with DAS and mine are the same as his, so I don't think it has anything to do with that. Again, I have no codes and everything looks good. Unless someone has another suggestion, I think my only other option is to replace the ECU.
Old Jun 25, 2018 | 05:21 PM
Serndipity's Avatar
2001 CLK320 Cabrio
Mark......to clone your ECU, using a donor ECU, means that you'll have to know what chip to extract from the donor and replace in your ECU. It's a pretty tricky and delicate operation as shown in this video, where the fairly easy immobilizer chip (e.g. with few connections), was extracted and replaced.
Here's another video, of a no start on a MB 2004 E500. It's 55 minutes long, not exactly your symptoms but worth watching, because the fault was no communication to the ECU, which was caused by it not getting power. The culprit was a faulty fuse in the N7-1, combination Fuse/SAM, (signal pickup and actuation) module. Turns out the fuse was not making a good electrical connection when inserted into the socket, due to corrosion.
Given that the ECU in our W208's s located in and powered by the N10/1 Fuse/SAM, could the issue be similar (e.g. ECU not being powered by the always present circuit 30 or switched circuit 87 voltage supply or ground) and why you were not able to pull any ECU DTCs?
Here are a few other possibilities.
I've enclosed some additional information that explains how DAS3 (drive authorization system) works and interior . Note that the ECU doesn't release the engine to start until after the 'ignition on' authentication check is made between the ECU and the EIS N73 fob. Also the N73 is a node on the interior CanBus. Have you tried your spare fob or checked for N73 communication DTCs?
Since you have been able to override the fuel pump operation, but still without starting the engine, I've also enclosed a diagram of the fuel supply system. Could a malfunctioning actuator, solenoid valve or pressure sensor be preventing the fuel pump from operating normally and/or preventing ample fuel delivery to the injectors?
Old Jun 26, 2018 | 09:45 AM
marko69's Avatar
This is more the direction I'm heading. After checking for spark and getting it good, the car should have started after bypassing the fuel relay. Yesterday, I checked the fuel at the fuel rail and got nothing when
the fuel pump was running. So I either have two problems or something in the fuel system is causing the ECU not to power the pump, as you say maybe an actuator or solenoid. (although I think I would get a code if that were the case)
Tonight I'll check that fuel is actual coming from the fuel tank to the pump and go from there.
Old Jun 26, 2018 | 10:10 AM
cm60k's Avatar
My friend had the same fuel symptom with his previous 00 W202 C43,,
after a month of searching, the issue was with the left fuel level/sending unit, it has failed,
replace it, everything back to normal,,
i can't assure you have the same with your fuel case, but prefer to check L&R level sender units, one could clogged or fail..!?!
-;ZAYED;-
Old Jun 27, 2018 | 06:17 PM
marko69's Avatar
Looks like I have at least a bad fuel pump. I can hear it running but there's no gas coming out of it. Hopefully when I replace it, I can get it running and the ECU will give me a code.
Old Jun 27, 2018 | 06:45 PM
cm60k's Avatar
You can pull it out & check it,
internal filter may gets clogged or it has bad check valve or even armature..!
-;ZAYED;-
Old Jul 7, 2018 | 11:34 AM
marko69's Avatar
Installed a new fuel pump, bypassed fuel pump relay to pressurize the fuel rail. Car started and ran just great. Turned off ignition, replaced pump relay, Turned on ignition and now I can hear the fuel pump run for a second and shut off, as it should. Started the car and it runs fine now.
I dunno, I suppose the ECU somehow reset with signals from a running engine.
Well, I was fully prepared to clone the ECU. From my research, it looks like a KESS V2 V5.017 software version v2.23 or higher would have done the trick. About $100 on ebay.
Old Jul 8, 2018 | 12:02 AM
cm60k's Avatar
Glad you beat it Mark, Thanks for sharing..
-;ZAYED;-
Old Nov 10, 2018 | 05:39 PM
marko69's Avatar
Well, it happen again. This time had to get the car towed home. Crank but no start. Same deal, no voltage at the fuel pump relay from the ECU.
I bought a KTAG ecu programmer from ebay for $85 and a used ecu for $25. Great thing about the KTAG unit is you don't need to desolder any chips
to read or program them. Able to copy the data from the 3 chips on the original ecu no problem. When writing to the used ecu I kept getting a write error
to the EEPROM chip. The other two chips were fine so I figured it was just a bad ECU. Ordered another used ECU from ebay and all 3 files wrote
correctly on it. Put it in the car and it fired right up with no problem!!!!! Saved a ton of money and the wife is off my back!!
I'll start a new thread with a video on how to do it.
Old Jan 4, 2020 | 12:50 PM
kmglamour's Avatar
2016 Mercedes C63S
i got these same issues on a 2016 C63S, replaced fuel pump twice and after week or two does same thing. Kicks over but won’t start, not throwing any codes but just won’t start. Was it main ECU you replaced ?
Old Jan 4, 2020 | 09:30 PM
marko69's Avatar
Yes it was the main ECU under the hood. Make sure you are getting the proper signal to energize your fuel pump relay. If not, then I would suspect the ECU or an input signal to the ECU (like the crankshaft position sensor). If you are getting a good signal to the fuel pump relay, then bypass the fuel pump relay and see if it will run.
Old Jan 12, 2020 | 03:45 AM
kmglamour's Avatar
2016 Mercedes C63S
got the scan tool and worked a treat, it actually found and cleared more codes than the star unit guy has been using from merc. Will update you all if car goes well for next week or two as that’s jdhdlky around time it has issues. Other thing found was main battery was too small so need to replace that.
Old Sep 25, 2022 | 11:51 AM
ChrsBowman's Avatar
2008 r350 4matic
Originally Posted by Serndipity
Hi Mark,
. I know this is an old post, but CPS....is this Crank shaft or Cam shaft...im having the same problem. Maybe I will replace all 4
Old Sep 25, 2022 | 01:17 PM
marko69's Avatar
