Engaged rear rollbar on 2000 clk 430
Old Jan 13, 2019 | 06:18 AM
Twinkle's Avatar
2000 clk 430 convertible
Need help on lowering rollbar. Anyone out there with the same issue. Reset switch will not disengage. Thanks
Old Jan 13, 2019 | 08:24 AM
Serndipity's Avatar
2001 CLK320 Cabrio
Did your roll bar deploy and become stuck in the raised position while operating the roof or an unintentional activation (e.g. such as an accident or avoidance of one, hard impact with a pothole, curb etc.)?
By reset, was that by pressing the dash roll bar switch and holding it into the up position for at least 10 seconds, until the roll bar drive mechanism audibly engages, then pressing the switch to lower the roll bar?
Old Jan 13, 2019 | 11:45 PM
Twinkle's Avatar
Car was parked on the street. I'm thinking someone may have tapped the rear bumper. No idea what happened. When I went to move the car back to the driveway, headrest were up.
Old Jan 14, 2019 | 11:02 AM
Serndipity's Avatar
2001 CLK320 Cabrio
Twinkle......it would require significantly more than a tap on the bumper for the mechanical system to extend your roll bar.
if it's in good working order, you should be able to lower an extended roll bar, as I suggested, just using the hydraulic system.
Alternatively, it's a PITA, but the roll bar can also be reacted manually.
Using the forum's search capability, you'll find the details of the procedure in a forum thread by member Aussiesuede .
Old Jan 14, 2019 | 05:03 PM
Twinkle's Avatar
i have no idea. When car was parked they were down when i moved the car 2 hrs later they were up. I didn't hear anyone hit the car. I was in the driveway the entire time. I will see what i can find. Thanks for your help
Old Jan 14, 2019 | 07:38 PM
Twinkle's Avatar
What does pita mean? Newbie and clueless.
Old Jan 15, 2019 | 06:42 AM
Serndipity's Avatar
2001 CLK320 Cabrio
PITA = pain in the *ss
Here's the thread that explains how to manually lower the rollbar.
https://mbworld.org/forums/clk-class...ering-how.html
Old Jan 15, 2019 | 04:47 PM
Twinkle's Avatar
Lol. Thanks again, I took a look at it last night. Will take car to my mechaniic to take a look at it. Headreast were up when i bought the car, so he is familiar with to time consuming task of manual retraction. I'm sure these steps will make it easier for him. Have a great day
