Service A....100 more miles. Few questions
Subscribe
Nov 12, 2001 | 09:06 PM
My car is reporting 100 miles till my SERVICE A. Would it be wise to call up the dealership in advance and schedule an appointment for service since I know it'll reach that 100 miles very soon? Or does the dealership need verification from the car stating that it is time for service?
Also, what type of work gets done? I havent had any problems with my CLK so far. Would they inspect my alignment since I changed my wheels to larger AMG monoblocks?
Thanks for the info
J
Reply 0
Nov 12, 2001 | 09:31 PM
Yes call up the dealer as soon as you can and make an appointment, don't wait until you pass those 100 miles. The dealer won't need verification. I can't list all the things that the dealer does for the A service, but they do do the usual, lube, oil change, oil filter change, and they check things like brake pads, but im not sure if they check alignment.
Reply 0
Nov 12, 2001 | 09:35 PM
Service 'A' Info
Flexible Service System - A-Service
- Change your vehicle's engine oil and filter
- Replace the dust filter in all SLK, CLK, C-Class and E-Class models
- Ensure the warning and indicator lamps, horn, windshield/headlamp
wiper and washer systems, and seat belts are functioning correctly
- Inspect tires and check tire pressure (including spare)
- Inspect brake pad thickness and disc condition
- Check and correct all fluid levels
- Reset your vehicle's FSS counter
Reply 0
Nov 13, 2001 | 03:23 AM
Check your service manual to see what gets done during Service A.
Reply 0
Nov 13, 2001 | 02:41 PM
You should definitely make an appointment right away. I made one here at the local dealer last friday, and the earliest time available is in mid-December!!!
Reply 0
Nov 14, 2001 | 11:51 AM
Call now
I had over 1500 miles and my dealer did the service now! They said better than bringing the car back again.
Reply 0
Nov 15, 2001 | 12:43 AM
Alignment
You are entitled to a free alignment before 12,000 miles.
Tell the dealership about the vibration...
Reply 0
Jan 9, 2002 | 10:21 PM
Re: Alignment
Quote:
We are? How do we get one - just ask for it or do we have to have a problem?
Nick
Reply 0
Explore
Jan 9, 2002 | 10:35 PM
Nick
How? Call your MB dealership's service dept.
If you experience uneven tirewear or have vibrations, you are entitled to the free adjustment.
If you installed larger wheels, lowered the car... then obviously there is a problem with free adjustments...you are on your own.
Reply 0
Subscribe
Currently Active Users (1)
