Subwoofer suggestions
Old Jul 29, 2004 | 09:38 AM
CLKBSVegas's Avatar
a Black
Question Subwoofer suggestions
I have the head unit, amps, speakers all picked and ready to go...but everywhere I go the installers scratch their heads at getting good, tight bass into my car without taking up the entire trunk or porting into the cabin. (quality, not quantity in my goal)
What have you guys used that works?
Old Jul 29, 2004 | 10:17 AM
Lorinser CLK's Avatar
04 CLK55
I have two 12" JL Audio subs ported through the rear armrest in a bandpass enclosure. The box doesn't take up the entire trunk. I have also seen installs that use one 12" inch sub that takes even less room. You can see pics of my install at this site: Lorinser CLK
Old Jul 29, 2004 | 10:56 AM
CLKBSVegas's Avatar
a Black
any shots of the arm rest?
Old Jul 29, 2004 | 10:58 AM
moa4r's Avatar
S4
^no you can't
Old Jul 29, 2004 | 12:27 PM
blackbenzz's Avatar
haters crazy
I have used 2 12W6 (older ones) powered by a ppi amp in my W124 and it hit, but nothing amazing. My brother has 2 10" diamond audio's and is using the same ppi amp i was using and his hits alot harder. I've heard good things about the w7's as well. What amp do you have to power the subs? If your just looking for clarity you should go with a bunch of 8's. The bigger you go, the less clarity but louder.
Old Jul 29, 2004 | 02:23 PM
CLKBSVegas's Avatar
a Black
The amp is...
The planned amp is an Alpine 250w x1. Thus, I would have to modify that purchase if I were to get a box with multiple subs. I am looking for the smallest sub set up so that I can get it out if needed...but I am not too willing to give up quality. My worry is a sub's sound, in the trunk, will not come through the seats.
Old Jul 29, 2004 | 02:35 PM
blackbenzz's Avatar
haters crazy
250W is not alot to power a sub, the sound will definitely travel through the seat though, you dont have to worry about that. You just wont be heard from a block away. Given that amount of power (assuming its an RMS value), I would just get a jl 10w6 or an eclipse 10" sub and call it a day.
Old Jul 29, 2004 | 02:37 PM
Petie's Avatar
2000 CLK430
most 12" subs dont need much more than around 1 cubic foot of airspace in a sealed enclosure. as far as bass making it into the cabin, youll have no problem with that. a couple screws will remove the barrier behind the armrest into the trunk. aiming the sub such that it is firing towards the trunk(away from the cabin) will give you more than enough sound. but if you want tight, accurate bass, steer clear of JLAudio and stick with a sealed enclosure. im using one Alpine Type R 12" in a sealed enclosure that takes up very little of my trunk. i can still easily fit two sets of golf clubs back there, along with being able to shake fillings loose if need be.
Old Jul 30, 2004 | 10:08 AM
ldangeli's Avatar
EFF YOU JACKIE
Subwoofer
CLKVegas,
I have an awesome Sub for sale if you are interested. Its a kenwood that I took out of my 911. It is a tube, and takes up litte space. I will get you pics if you are interested.. Let me know.
Old Jul 31, 2004 | 08:48 PM
ericktu's Avatar
W211
i have two brand new JL 12W7 and a 1000/1 amp for sale.... Give me a private message if interested
Old Jul 31, 2004 | 10:31 PM
ViKTORiOUS's Avatar
W209 - W163
I have 2 JL 12W7's in a W7 Box, and they P O U N D
Old Aug 1, 2004 | 04:17 PM
blackbenzz's Avatar
haters crazy
Viktorious- what kind of amp is pushing your w7's and whats the rms output? Do you have a problem with rattling noise cuz I did in y W124 (the gas tank would rattle like crazy!).
Old Aug 1, 2004 | 05:52 PM
ViKTORiOUS's Avatar
W209 - W163
JL 1000/1 Amplifier and a 500/1. Not sure how many OHMS I was pushing.
Old Aug 1, 2004 | 05:57 PM
ViKTORiOUS's Avatar
W209 - W163
JL 1000/1 Amplifier and a 500/1. Not sure how many OHMS I was pushing. I can check for you, I got the whole trunk Dynomatted because of the rattling... Insulated everything, after the dynomat, the tank cap wasn't rattling. However, my levels were fairly low, bass was set near -3 and treble was +5. Excellent sound with the Bose combo if you keep the speakers, however i eventually dropped in MB Quart components in the doors, which is why I bought the 500/1 amp, to push just the speakers alone. Very awesome setup, and man did they knock.
Old Aug 2, 2004 | 10:08 AM
blackbenzz's Avatar
haters crazy
You ran 2 subs off a mono output amp? And when you replaced the speakers with mb quarts, did you replace the 2 speaker sets and the tweeter in the door and the set in the rear decklid? Because I have a 4 channel PPI amp and plan on getting the same setup you have but I thought I would have to choose only 4 speakers plus the tweeters (leaving one set of speakers functionless).
