Clk 320 Cold Intake!!
Old May 9, 2002 | 09:25 PM
x15jq's Avatar
Hey everyone,,
I bought it from MBKID, he is on the w202 c class forum
Its a custom Akimoto intake modified to fit the clk
I really was skeptical at first
BUT IT ADDS SO MUCH THROTTLE RESPONSE
and the NOISE is SO COOOLL!!
Check out a pic
Old May 9, 2002 | 10:23 PM
Ahmed's Avatar
R129 SL55 AMG & W208 CLK55 AMG
thats so cool
i've just ordered the cone filter induction kit for my 320 from DEMON TWEEKS in the UK. Will it give me the same effect, i heard the sound is different too!!!
i'll have to customize the pipe and adapter though!!
Old May 9, 2002 | 10:28 PM
Blackdog's Avatar
2006 E55
Is that picture of your car or of MBKID's car?
Old May 9, 2002 | 10:32 PM
x15jq's Avatar
Thats my car
Yea Ahmed, the cone filter will do just that
But how are u mounting it? there has to be some sort of pipe I dont think just a cone would fit under the hood
Old May 9, 2002 | 10:37 PM
Ahmed's Avatar
i'll probably customize a PVC pipe and the adapter. I've also purchased an aluminized CLIP ON shield so that the warm engine air don't get into the filter. its really cool cause its round and clips onto the filter itsef shielding it from the surroundings.
Old May 9, 2002 | 10:51 PM
x15jq's Avatar
Thats cool
If ur wondering how to connect it to the air sensor body, I used a 3" wide piece of neoprene tubing. its really strong and holds it fine. The piping i have is aluminum, pvc would work I assume, but wouldnt look as good. If you can get a black pvc to match the rest of the intake tubing that would be phat.
Lemme know if i can help u with anything on it.
Old May 9, 2002 | 10:55 PM
Ahmed's Avatar
thanks alot
thats exactly what i plan to do.. paint it black... although i would love to have the whole pipe aluminium color cause the shielder is aluminuim too!! hmmmmm....
anyways, can't wait to get it, should be here by monday. I'll let you know how it goes...
thanks again!
Old May 9, 2002 | 11:04 PM
x15jq's Avatar
No problem if u DO want an aluminum chrome pipe
Go to ANY racing shop that sells honda cold intakes.
Look at one, and get it, the one i have is simply one that was cut with a hacksaw so it works
Old May 9, 2002 | 11:10 PM
Safet's Avatar
Just curious, how does this device get cold air into the engine? Wouldn't this just increase hot air going into the engine?
Old May 9, 2002 | 11:41 PM
Mach430's Avatar
Running the intake to the side, rather than over the engine, allows you to bypass a lot of heat from the engine (as heat rises). This would be much more effective if a heat shield was used to prevent as much heat as possible from reaching it as well.
This is for a BMW application, but it's the same idea:
Old May 10, 2002 | 06:27 AM
Ahmed's Avatar
finding autopart shops that sell Honda stuff should'nt be a problem... THEY'RE EVERYWHERE!!!!
thanks X15jq
Old May 10, 2002 | 12:50 PM
x15jq's Avatar
Yeah, mach430, i do think i need to create some sort of heat sheid. what is that bmw one made of
there DEFINATLY is a performance increase and the engine sounds so much better
Its 88 degrees here today and it doesnt feel sluggish at all, just better than befoe!
Old May 10, 2002 | 02:42 PM
sungulent's Avatar
2002 mercedes clk coupe
thats cool where can i get one??? and how much are those things?
will a mb dealer install those things?
Old May 10, 2002 | 03:25 PM
CiLKY's Avatar
13 S550 4Matic
I just made a cold air intake for my 2001 ml 320 which has the same engine layout as you guys and the sound is awesome. I just got my clk 430 today and I'm gonna make a intake for it. I will probably start making these and selling them. The only intake I've seen for clk's (430) was priced at 1200!!!! yikes.....
If if can get one made out of Lexan(bullet proof) or aluminum how much would it be worth?
Let me know
Jeremy
Old May 10, 2002 | 03:58 PM
shy's Avatar
shy
200 clk 320
more inof on the intake pls ...
can you give more details ? like $$ and how can i get one ?
Does this void warranty ?
thanks ...
Old May 10, 2002 | 04:08 PM
CiLKY's Avatar
13 S550 4Matic
I don't believe that an intake will not void your warranty unless the problem can be traced back to the intake. In other words if your car has a tailight problem I doubt your intake had anything to do with it hahaha. The intake you see on the 320 above would only cost a hundred dollars or so on ebay. However if you made a heat shield to go with it then it would probably go for 250 or up.
I'll see how good of a heat shield/intake I can make and see if possibly evo-sport wants to sell them. I've already made a unit for the audi TT and bmw e-36 series. After I get this one made I may start selling them on my web-site.
L8tr guys
Jeremy
Old May 10, 2002 | 04:15 PM
shy's Avatar
shy
200 clk 320
so.......
couldnt i get this one you posted the pics of ? Bare with me, Im new to the idea of intakes .. but im diggn the idea....
Old May 10, 2002 | 04:19 PM
CiLKY's Avatar
13 S550 4Matic
Hey Shy,
Yeah you can go on ebay and find an intake for a 3" hfm(tubing) and get a piece of silicone tubing to fit it on to your 3.5 air flow meter. I'm not selling these or nor did I make the one pictured I am thinking about making them in the future however.
just go look for 3" cone filter on ebay and see what you find or I'll post a link to one myself.
L8tr
Jeremy
Old May 10, 2002 | 04:25 PM
sungulent's Avatar
1200 dollars??? im nto trying to b cheap but 1200 dollars is too much for some air intake
i was thinking of 2 or 3 hundred max
nawh i guess im not gonna get it
thanks alot for the info fellas
g
Old May 10, 2002 | 04:28 PM
CiLKY's Avatar
13 S550 4Matic
I would get one.... what I was saying about 1200 was that I saw one for a clk 430 that was 1200 (it was carbon fiber and so on)..... but you could get one for your car for much much less.
I could make one for 250 and send it to you. If anyone is near Asheville and wants to have the test subject clk 320(I have the 430) and I've already got one for the ml-320. Then it could be done pretty easily.
L8tr
Jeremy
check out this kit on ebay which would work on a clk 320
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1827626098
it doesn't have a heatshield though.
Old May 10, 2002 | 06:58 PM
Ahmed's Avatar
the K&N filter cost me 100 bucks including the cleaner. The shield cost 35 bucks. I'll need to customize the pipe and adapter, but thats peanuts!
the filter is 3" ID
dimensiaons are 3 5/8" by 6" by 9"
