need help figuring out problem
Old Aug 29, 2004 | 04:53 PM
2SYKbenz's's Avatar
I need some help trying to figure out a problem Im having with my CLK.
When im driving at a constant speed the rpm's will drop about 200-300 and the car rumbles (like you are driving over a rumble strip) and a few seconds later the rpm's go back up to normal and the cars fine. It does it at 25 and also higher speeds like 50-60. Sometimes it only does it once or twice and other times it will do it every few minutes for awhile.
Car is an '02 320 with 40k on it.
Any thoughts are appreciated-
Old Aug 29, 2004 | 08:20 PM
Hot-Clk's Avatar
2002 Clk 55 Amg
Dos it happen when you go up hill???
Old Aug 29, 2004 | 08:39 PM
2SYKbenz's's Avatar
no, it happens on flat open roads going a constant speed
Old Aug 29, 2004 | 10:56 PM
Mach430's Avatar
Hmmm... Do you have any other problems while driving? Any hiccups while accelerating? Is the car shifting gears when this happens?
Old Aug 29, 2004 | 11:03 PM
2SYKbenz's's Avatar
all the abs and other brake lights came on with it one time and this problem was blamed on that.
Brakes fixed and now this problem is happening more and more.
I am not sure whether the car is upshifting for a second and then going back into gear. Its more like in a stick if you half put the clutch in and then let it back out.
Other than that car runs perfectly
Old Aug 30, 2004 | 04:15 PM
midget fidger's Avatar
E550 Coupe
mine did that once or twice. hardly ever happens. its like you said - putting it halfway into a lower gear then switching back to normal
Old Sep 2, 2004 | 02:34 PM
ldangeli's Avatar
EFF YOU JACKIE
Most likely the (MAS) Air Sensor. I believe there was a recall on them.
Old Sep 6, 2004 | 10:30 PM
2SYKbenz's's Avatar
thanks for the input- going to the dealer when I get time which is hopefully soon
