Convertible Top Will Not Go Down CLK 320 W208
Old May 31, 2021 | 03:33 AM
Acento's Avatar
Mercedes clk 320 sport (W208), CLK 320 Convertible (W208) 2001 model
HI Every One,
First time on the MB world forum, Please forgive me if I have posted question in the wrong section, If so please advise me
I Need some advice on my CLK W208 320 convertible, 2001 model Please
When I turn & open the roof handle, all 4 windows come down, but nothing else happens, the convertible roof switch is not flashing & the red light remains on, The boot is close & luggage compartment cover is in place, I have also changed the relay on top of the pump, but nothing happens, hydraulic fluid is just below the max mark & the rear safety bar, does not go up or down, I have also checked all the fuses (non are blown).
Please Help.
Many Thanks
Old Jun 2, 2021 | 06:16 PM
Mercnotworking's Avatar
CLK 230 Convertible 1999
Hi,
Welcome to the forum.
The 208 hydraulic roof system is complex and so difficult to diagnose and fix. I spent 18 months tinkering with my system before I found and replaced the sensor that was causing the malfunction. It has worked brilliantly ever since, I'm pleased to say.
My first tip would be to spend a couple of evenings studying the threads on this subject on here. Especially this one: https://mbworld.org/forums/clk-class...-failures.html
Here is how I solved my roof thanks to very helpful advice from Serndipity - https://mbworld.org/forums/clk-class...p-problem.html
There are some very helpful videos on YouTube especially from TopHydraulics and AutoRepairGuys.
BTW, sometimes opening and shutting the roof manually can jumpstart the system.
Good luck!!
The
