Here's what I found at 94,449 miles...
Old Sep 29, 2004 | 10:08 PM
brianw430's Avatar
'03 G500, '11 S550 4Matic, '12 SL63 AMG, '13 ML350, '16 AMG GTS Ed. 1
I just got back from my mechanics after he did a 20,000 mile service on my 430, which included a tranny service. He replaced the plugs and showed me the old ones, I could not believe how much the "electrode" had worn to nothing. It was literally almost completely worn to the top of the spark plug. My car was reading a miss fire in cylinders 1,3 & 4 prior to the new plugs...no longer getting this reading. The plugs were Bosch platinums with 20,000 miles on them.
He also said the tranny fluid "needed to be changed!" I now have a much, much, much smoother shifting tranny. I had not realized how the tranny was not performing over the course of 94,449 miles! For those of you considering changing the tranny fluid and filter, do it at normal intervals, not the MB way. It took 11 quarts of fluid at $8 per quart, $5 for pan gasket and $11 for filter, roughly, plus labor. Worth every penny.
Take care!
Old Sep 30, 2004 | 12:51 AM
Brian_I.'s Avatar
w211 & w124
That is exactly the mileage I am at right now and my tranny just isn't performing how it used to. Did your call have a rough idle when cold before the fluid flush?
Old Sep 30, 2004 | 10:04 AM
Scottie420's Avatar
CLK 430
Was that done at the dealer or an Mechanic who specializes in MB service. I'm jsut wondering how much the dealer would hose me if i took it there..
Old Sep 30, 2004 | 11:20 AM
brianw430's Avatar
It was getting a rough idle when stopped, but that was from the misfires in the cylinders...according to my mechanic. The tranny is just so smooth now it is hard to believe how it used to be. I feel as though I had neglected service on my car. Some really assuring preventative maintenance.
I took it to an independent MB mechanic who specializes in MB and Volvo only. He has very reasonable shop rates, very knowledgable and very fast. I would trust him with my wallet. One of the more honest people I have come across. He is also an aviation mechanic.
Hope this helps!
Old Sep 30, 2004 | 01:45 PM
drli's Avatar
CLK430
I find it hard to beleive that you took out a set of Bosch platinum plugs at 20,000 miles. These are suppost to last ~100k in our cars.
Old Oct 1, 2004 | 02:24 PM
brianw430's Avatar
I have no idea how long these plugs are supposed to last, but these plugs had only 20,000 miles on them and they were physically shot.
Could that possibly be a symptom of something wrong with the engine? In my car, there is no way they would ever come close to 100,000 miles...and I do not drive agressively.
Old Oct 1, 2004 | 02:40 PM
moa4r's Avatar
S4
^how much were you looking to get for your 430, just curious?!!
Old Oct 1, 2004 | 06:30 PM
drli's Avatar
CLK430
I’m not a mechanic so I am not really sure…. But may be the sparkplug gap was set incorrectly or something…
May be someone here would know more about this then I do. It just seem strange that they would only last 20K. I had about 45K on mine when I had them changed... and the ones that they took out looked ok, I mean you could tell they were used and all, but they didn't look that bad.
Old Oct 6, 2004 | 12:13 AM
Maestro's Avatar
W208 CLK320 & E39 M5
Can't you have Jiffy Lube flush the transmission fluid for less than half the price?
Old Oct 6, 2004 | 11:09 AM
brianw430's Avatar
Wink
Um, possibly, but Jiffy Lube will never touch my car!
Old Oct 6, 2004 | 12:27 PM
proform's Avatar
Ferrrari 458 Lamborghini SL 570-4 Mercedes CLS63
I brought my W208 CLK55 to Jiffy Lube and they were happy to change the oil.....Iam not proud of it but I did it.....
Old Oct 6, 2004 | 03:54 PM
midget fidger's Avatar
E550 Coupe
not sure if it was on this forum or somewhere else, but i heard someone took their car to jiffy lube for an oil change...and they forgot to put oil back into the engine. our personal experience was that they used the wrong size tool and stripped the screw for the oil
Old Oct 6, 2004 | 07:01 PM
Maestro's Avatar
...and you probably saved a couple of hundred bucks in the process.
Old Oct 6, 2004 | 07:02 PM
Maestro's Avatar
We've also heard numerous "horror stories" about MB Service making idiotic mistakes.
Old Oct 6, 2004 | 07:05 PM
E550 Coupe
yea, good point. i don't go there anyhow, too expensive
Old Oct 6, 2004 | 08:13 PM
Bagher's Avatar
1999 CLK430
i work at my dad's shop and you wouldnt believe how many ****ed up jiffy lube'd cars we get, if you can afford a benz, take it to a shop with mechanics, not teenagers making minimum wage. That being said you don't have to take it to the dealer and get raped either. Take it to an independent shop that will do a good job that will be a little more than jiffy lube but just as good quality service as the dealership.
Old Oct 7, 2004 | 11:44 AM
brianw430's Avatar
Bagher, my point exactly. Not saying Jiffy Lube does not have good people, but I know my mechanic, I know the local Jiffy Lube reputation, and for the difference, my mechanic is light years ahead of anyone in the area, especially the dealership.
With that being said, the local MB dealer just lost their rights to the line and it has moved to a dealership about 2 blocks from my office. Wonder why that happened...? i only hope they will do a "better" job than the prio dealership.
