Advice: Dashboard Lights Flickering
Old Oct 25, 2004 | 12:47 PM
cscordo's Avatar
2001 CLK 320
For the past day or so, what appears to be a light behind the dashboard display has been intermittently flickering on and off. When its off, the clock display is barely visible, as well as the right-side portion of the main info area.
Any idea what this is and how much it may cost to get fixed?
Old Oct 29, 2004 | 06:00 PM
Dan Wang's Avatar
E320CDI, CLK55, and a Smart
It could be as simple as some loose wiring behind the cluster. If its intermitent, try taking out the cluster and confirm that the wiring is tight.
Old Jul 8, 2014 | 12:01 PM
seattledani's Avatar
2001 CLK 430
Hey, did you fix it? I have the same problem!
Old Jul 8, 2014 | 12:23 PM
MarcusF's Avatar
2002 CLK430
Check the bulbs. One of mine went/was going, so I just ordered a complete set from Autohaus AZ. The bulbs are inexpensive and a normal wear item.
