I could use some help identifying the hardware used to attach the front bumper cover to the fender on a 2003 CLK 430 Cabriolet. It is the long 10mm screw that is in the middle of the upper rail. I could also use both upper rails replacements as well.
I currently have the car masked for paint, so I am not able to show the actual part at the moment. So I used the parts catalog that shows the upper rail and where the screw would be located.
if you have the bumper off get screw from other side, go to hardware store, match up screw and install...Or look for a 10mm screw instead...Always seek a new route. GL.
R,
2Merks
FYI for anyone searching for this in the future, it does appear the part is available and according to mbpartscenter.com it is $4 and change (as of 7/13/24 anyway).
