problem : p0300; p0301; p0302; p0303; p0130 appeared at the same time
Old Nov 20, 2024 | 02:33 AM
Davit tsereteli's Avatar
Mercedes Benz CLK320 w208 1998
hello everyone. on my 1998 CLK320 v6 appeared p0300; p0301; p0302; p0303; p0130 codes at the same time and now engine has detonations and fuel consumption has increased. has anyone experienced such situation?? if so please give me advise what might be the reason.
thank you
Old Nov 20, 2024 | 05:08 AM
ygmn's Avatar
2015 E400 Sedan
Those misfires need to get checked out before you ruin cats.
could all be due to problem with O2 sensor or circuit on Bank 1.
Need to properly troubleshoot or you end up just buying and replacing good parts until you end up finding issue or bad part.
Heck could be a popular fault on these cars/engine worth researching out.
OBD-II Trouble Code: P0130 02 Sensor Circuit Malfunction (Bank I Sensor 1)
Old Nov 20, 2024 | 06:11 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W208 forum...
Old Nov 25, 2024 | 10:55 AM
ML Dude's Avatar
How scanned?
If you’re using a a simple OBDIi scan you’ll only see emission codes. You need a much more capable scanner connected via the round 31pin connector in the engine compartment. I’m sure you’ve already looked up these code meanings. Once you have a good scanner, notate and clear and drive to see which ones return and need attention, good luck!
