Instrument Cluster Failure?
Is there anything i can do to fix this problem?
I think something is loose or has a bad connection as i can give the display a whack and it will be fine for a while before going off again!
Help!
Ted
These flexible printed circuits are GLUED to the main board and generally trying to remove the flexible printed circuit to repair it will destroy it, so you need to have a replacement at hand already. Generally what happens is excessive vibration (despite being held down by a piece of foam rubber which is supposed to dampen the vibrations) will cause traces on the flexible printed circuit to break. This usually happens at a weak point, which is right after the PC exits the rubber vibration dampener.
If you can repair the actual PC (esp. after you destroy it when removing it), you are an electronics god. If you can get a replacement PC, you are probably a parts supply god or are on intimate terms with someone from VDO.
If you're adventurous, you can replace the whole flexible PC link with something like wires, but it will require a lot of work because the other end of the flexible PC is attached to the LCD.
-s-
I wrote that you are an electronics god if you can REPAIR THE PC (the flexible PC) after you destroy it by removing it. Attaching it or attaching one that has come off is easy... just a spot iron (or you can make-do with a soldering iron). But removing it, finding/fixing the broken traces (which is most of them) by using conductive paint, and reattaching it and having it all work... that's skillz.
Generally the glue doesn't fail because of the foam rubber block holding it in place. But yours might be different. I'm just reporting back my findings on about 15 broken ones, it all tended to be a broken PC.
Give it a try! You have nothing to lose, and you might be able to get it back to life. If you have a donor cluster with another good LCD, you might be able to salvage the flexible PC from that one (one that is not broken is a lot easier to remove without hurting it), with some patience.
-s-
.........if what you think is the problem is actually the problem, can you explain why the missing alphabets and numbers dissappear in cold weather and re-appear when the car warms up?
ted
Take your cluster apart and take a look, so we can be on even footing when we're discussing this. I think you're not completely understanding how the cluster is constructed, and if you take a look, it will be easier than me trying to describe it to you.
-s-
http://www.beckmanntechnologies.com/
If they can't help you, you need a new cluster.
