Squeal like a pig...
I just replaced the front/rear pads and rotors on my CLK 430. I used OEM parts all around, plenty of anti-squeal paste on the back of the pads and now the brakes squeal when braking.
The noise is only audible when braking at speeds of less than 10 mph. Braking at any other speed is fine (and silent)...
Any suggestions?
-Dan
Any suggestions?
-Dan
230k clk cabrio (w208)
it's all good
hey mate,
had the same prob in my clk cab it was fxxxing annoying but drove the car approx 300 miles and all the noises and sqeuking were gone had new pad fitted all round
cheers don
cheers don
CLK320
had the same problem. Turned out the hub was bent and the rotor was rubbing against the pad at slow speeds. Changed everything from the knuckle outwards and the problem was fixed. Could also be the flimsy backing plate rubbing against the rotor.
Originally Posted by pigman
Whoops. Pigman heard someone calling out.
Or another possibility could be that one of the pads in on backwards and the wear sensors are just squeeling away? I don't know, just throwing in other possiblitites.
Thanks for all the replies.... I forgot to post a follow-up.
I took the wheels back off to check everything and I found that one of the bolts that hold the driver side front caliper had wiggled its way loose.
With the caliper only tightened down with one bolt it suppose it caused enough vibration at low speeds to squeal.
I re-torqued the bolts and it has been quiet ever since.
-Cheers!
-Dan
-Cheers!
-Dan
Originally Posted by J Lucas
Just curious, how much did it cost you for (4) Four rotors and Front and Rear brakes? Total? + service?
Zimmerman cross-drilled rotors (front)
Zimmerman solid rotors (rear)
ATE pads (front & rear)
Anti-Squeal Paste
OEM Brake sensors (front only)
The total for the parts was $400. I did the job myself with just a few basic tools and it took me about 2 hours to complete the front and rear. My local stealership quoted me $1200 for parts & labor. When I asked them why it cost so much, the service advisor said "...well mercedes are very complex cars."
I laughed for 2 whole days
-Dan
