Anyone changed their Brabus front bumper bulbs?
2003 CLK320, Sliver, Ash Leather, Command System, Xeon lights, K3, K4
Hey guys with Brabus front bumper,
One of my bulbs just burned out...anyone atempted to buy different set of bulbs then from brabus....i don't like how i have xenon lights and my fogs are regular.
thanks
thanks
Hey, I am in the process of converting my fogs to HIDs. The regular ones are useless. Why do I hear often about the Brabus lights burning out? Want to do a group buy for HIDs? Let me know.
sure....i just want new bulbs....i'm taking this opportunity since one of my lights burned, i'm going to replace all four. But lets do this quick...i hate driving around with 1 bulb burned out.
Hello, I just changed mine last week. Brabus uses H3 bulbs for the fogs, only thing is the h3 they use has a special plug which you will need to use when changing the bulbs, on the brabus ones the ground wire (black) is grounded with one of the screws that's holding the bulb and the white wire that's connected to the bulb itself is the one you need to cut so you can use the original plug. Once you have the plug simply use a connector and connect the wire to the new bulb. Since we have 4 fogs I changed the outter ones to ion crystals and the inner ones to hyper white came out quite nice.
didnt get a chance to take some new ones after changing the outter ones to ion crystal these were taken when both are using hyper white. I'll take some new pics with the ions when i get a chance.
sure thing. The fogs you can use pretty much any hyper white h3 bulbs they sell on the market. The ones i used was from this guy http://cgi.ebay.com/ebaymotors/ws/eB...&rd=1&tc=photo
Its pretty cheap, $12.99. Then after a while i changed the inner ones to piaa h3 ion crystals which cost a bit more. The city light is using led wedge bulbs instead of normal light bulbs.
No specific reason for changing the inner ones to ions, I just think its too much white and wanted some yellows. As for replacing the bulbs, I'd be lying if I told you it was easy. If you have access to a lift where you can lift up the whole car and be able to move around under the car then changing the bulbs for you will be very easy. In my first post on this topic I have mentioned few details on how to change them if you need more details i can show you step by step if you decide to change them. The led conversion I got the leds from this site http://www.superbrightleds.com/1157.htm its the WLED-x6 LED Wedge Base Bulbs those are the closest color to match hids. You will also need the load equalizer for each led you install. They also sell those on that site.
