My Car Has the Coolant Contamination Problem
Old May 17, 2005 | 04:27 PM
Frisco's Avatar
03 CLK500, 04 X3, No 07 GT3RS :(
I just got word that they found coolant contamination in my transmission and are going to replace it
Old May 17, 2005 | 04:47 PM
TX4Runner's Avatar
'03 M5
Sorry to hear that. But it's better to have it fixed now.
BTW - Why the change to your sig? I liked the picture of your car.
Old May 17, 2005 | 04:59 PM
RJC's Avatar
RJC
Various
Sorry to hear this, I'm sure she be as good as new. Please find out from the shop foreman of you rdealer, what production dates could be effected by this.
Old May 18, 2005 | 09:21 AM
x-tian-230k's Avatar
CLK500/Range Rover HSE/E55 AMG/Bmw 328Xi coupe/BMW 4.8x/Bmw 335i/GS350/Audi S5/E350
Frisco, that is one of the issues with CLK's. Especially with 03 and 04's. My car, Jlee and Starr have had our transmissions replaced due to this issue. My car drives like new with out any issues.
Old May 18, 2005 | 10:28 AM
Frisco's Avatar
That's what I'm afraid of!
Old May 18, 2005 | 10:31 AM
Frisco's Avatar
I forgot to mention that they told me that there is a recall on the door seal that's going to be announced shortly. I put the new sig up because of some plans that I have for the car in the future.
Old May 18, 2005 | 03:00 PM
clkcadet's Avatar
S550
frisco, what were some of the symptoms of this transmission problem? just so i can look out for them!
btw do you ever have any problems with warranty issues? or mbusa doesnt mind the mods?
Old May 18, 2005 | 03:32 PM
Frisco's Avatar
There was a subtle grinding during gear shifts and a bit of forward and backward motion at constant low throttle around 2k rpm. They definitely do not cover any items modified, but pretty much all of the mods are cosmetic.
Old May 18, 2005 | 06:28 PM
clkcadet's Avatar
S550
oh, so lets say from downshifting 2 to 1 i hear and feel a slight grind is that what it is? i mean i dont notice it much on the other upshifts but maybe im not paying close attention....
Old May 18, 2005 | 08:58 PM
Cadet,
YOu will definately feel the grinding noises. ITs not subtle at all....i felt the grinding noises between 40-70 MPH when the gears were shifting...
Old May 19, 2005 | 09:21 PM
RJC's Avatar
RJC
Various
Question
What can be done to prevent this problem from occuring and or what causes this to happen?
Thanks,
Old May 20, 2005 | 12:21 PM
Frisco's Avatar
It's still not clear to me what causes it. I just got an update (and saw the car on the lift) that they are changing out the radiator and all lines as well. The new transmission just arrived, and they said I should have the car back Mon or Tues.
Old May 20, 2005 | 08:51 PM
RJC's Avatar
RJC
Various
Most auto transmissions are cooled by the radiator, so if they are replacing the radiator too, it seems there is trouble with the radiator or one of its related components infecting the trans with coolant.
Please Frisco, the next time you visit your car ask the tech or better yet the shop foreman what MB can do to prevent this problem from occuring in cars not yet affected.
Thanks!
Old May 24, 2005 | 12:31 AM
Frisco's Avatar
I wasn't able to get any more information about the problem. They replaced the radiator, all hoses, and the transmission. They also replaced the driver door lower seal.
Old May 24, 2005 | 10:39 AM
RJC's Avatar
RJC
Various
Thanks anyway...What happened they wouldn't talk about it?
Old May 24, 2005 | 10:45 AM
Frisco's Avatar
It wasn't that bad - I just went right right at closing to pick it up. The service advisor was already gone for the day, and the only people around were the cashier who processed the paperwork and the parking attendant that pulled the car around.
Old May 26, 2005 | 12:09 AM
Frisco's Avatar
Problem solved - the hesitation and grinding are gone.
Old May 26, 2005 | 03:03 PM
clkcadet's Avatar
S550
weird, my grinding stopped but i still have hesitation...should i still take it in to benz?? maybe im missing the grind since i got used to it?? (i only get it from 2-1 downshifts but hesitation from most upshifts)
Old May 31, 2005 | 10:26 AM
STARR's Avatar
2003 CLK 320
Yes I'm going to take mine back to service, I'm getting the hesitation. When the car shifts from 1 to 2 it's like my car kind of "hiccups" (no sound just a slight jerk). It used to be a smooth transition.
Old May 31, 2005 | 10:32 AM
STARR's Avatar
2003 CLK 320
Symptom: When the car hit 1100 rpms and/or 2300 rpms it would make a loud grinding/rubbing sound. Initially they thought it was my exhaust.
Old May 31, 2005 | 10:34 AM
STARR's Avatar
2003 CLK 320
Thanks,
There is nothing you can do to prevent it. The official Mercedes Benz story for the trans replacement is: The coolant line that runs through the radiator deteriorated allowing coolant to mix with the trans fluid and contaminated the trans. They tried to replace only the torque converter but the noise was still there so they replaced the entire trans.
Old May 31, 2005 | 07:41 PM
RJC's Avatar
RJC
Various
Thanks Starr. It sounds like MB should be replacing the radiators on cars within a certain production range to prevent this problem. Knowing MB though,they won't and they'll have more unhappy cutomers with failed transmissions....
Old Nov 28, 2006 | 04:58 PM
britton's Avatar
2003 CLK 320
transmission problems?
Just took 2003 clk in for my last free service with 33,000 miles and
they found radiator coolant in the transmission. Was told they are going to
flush coolant out and see if this works. If this does not work they are going
to replace transmission. Has anyone had this problem and what did they do?
My warranty is up in three days. any advice would be welcome.
thanks britton
Old Nov 28, 2006 | 09:39 PM
blk350c's Avatar
CLK350C
the radiator is actually the culprit. the new radiator being put in is an updated part to prevent this from occurring again. now don't confuse the bucking and jerking at low speeds with this same issue. the transmission control modules on the 03-05 clk320's cause that problem. the grinding and awkward shifting is what to look for with the contaminated trans. a glykol test is done first to verify the issue. if it has not damaged the trans, they will flush the trans, than replace the torque converter. Of course the transmission gets replaced last. Usually the first two steps do not resolve the issue, so the trans usually has to end up being replaced. good luck to those with the problem.
