Brake squeeking?
Any thoughts on what might be causing this?
Thanks in advance for your help.
I have a 04 CLK500, 39K miles. Brakes are squeaking while moving at slow speed. Dealer inspected and said that pads and rotors are fine. He said that there may be a "film" on the pads and rotors and advised me to brake really hard while going fast to even the surfaces out. Does this sound reasonable? Any other thought about how to fix this?
What you are experiencing is soft brake components. MB uses soft pads and rotors to give you excellent brake feel and performance. A glaze will start to build up btwn the pad and rotor. What you are hearing is a squeak due to vibration of these parts against each other. I periodically take my car to a speed of about 80mph and slam on the brakes(please make sure no one is behind you). This is what the service department does to "de-glaze" the brake parts. There is also a spray that is applied to the rotors and a paste that you can put on the pad to keep the noise down. You just need to get on the brakes every once in a while and you will never hear a squeak until they are actually needing replacement. Don't go and put new pads on because it is more likely that you will continue to experience a squeak with worn rotors.
