Dyno?
Old Dec 12, 2005 | 12:06 AM
joeybenz106's Avatar
2007 cls 550
Dyno?
ok well i have tryed to put my 2003 clk on a dyno but the esp off but it still blinks and doesnt let u rev it out. any ideas?
Old Dec 12, 2005 | 12:18 AM
vraa's Avatar
Set the car into Dyno mode.
You should be able to find instructions somewhere.
Old Dec 12, 2005 | 02:22 AM
2007 cls 550
i havent been able to find away to set it in to dyno mode... i have searched also still no info
Old Dec 12, 2005 | 03:06 AM
AMG_55's Avatar
mymbonline
i believe only 05 cars and up have dyno mode.... u need a 4 wheel dyno.
that way the rear spins the front and rear rollers and the car thinks its driving
good luck
Old Dec 12, 2005 | 02:10 PM
2007 cls 550
Talking
i found out how. this works for the clk
Fully disabling ESP
I don't know if anybody outside of the dealer is aware of this, but the traction control can be completely disabled simply by use of the steering wheel buttons. Here's the low-down-
1. To start, the key must be removed from the ignition.
2. Insert the key and turn to position 1.
3. Immediately press and hold the trip odometer reset button until the instrument cluster beeps. There is no visual message, only an audio beep. Be patient, this takes around 40 seconds.
4. Press the lower menu button (it looks like two sheets of paper, the one with the writing in the background behind the blank one)
5. Press the up arrow button.
6. Press the "+" sign to disable the Traction System (turn "ON" test mode)
7. Start the engine, the traction system is now disabled.
To return to normal, remove the key and restart the engine. The traction control warning should no longer be in the cluster. If it is, shut the engine off and remove the key again. Then insert the key and turn to position 1. Note that the DYNO test screen is displayed immediately. Push the "-" button to enable the traction system (turn "OFF" test mode)
NOTE: When you first turn the key to position 1, ESP DYNO Test screen pops up, then after 1-2 seconds it may disappear while faults are displayed. If you weren't fast enough in pressing the "-" button before codes were displayed, just wait until all codes cycle by, then the ESP DYNO Test screen will reappear.
Old Dec 12, 2005 | 04:27 PM
AMG_55's Avatar
mymbonline
r u 100% sure this works on the 03 moedels?
if yes, i feel sorry for my tires :p :v
i know it works on 05 models 4 sure, i've done it on many loaners and my mom's e55
thanks
Old Dec 20, 2005 | 11:31 AM
rsatmans's Avatar
None
It works on my 2003 clk500 Thank you
Old Dec 20, 2005 | 02:49 PM
Frisco's Avatar
03 CLK500, 04 X3, No 07 GT3RS :(
sweet, it works!
Old Dec 20, 2005 | 08:57 PM
PTE's Avatar
PTE
05 ML-500 , 03 CLK5.5 AMG has left the Garage
dyno mode
it works on my 2003 CLK 55 amg . I've do over 20 dyno runs. It works everytime
