2004 CLK500 dash removal
2003 clk55
Does any one have know how to remove the wood trim around the radio in a 2004 clk500? Does any one have the diagram of it from a wis cd?
Thanks in advance
Thanks in advance
1 Post
03 CLK500, 04 X3, No 07 GT3RS :(
Yeah it's easy - there's 2 torx heads securing it at the base of the wood panel, and to access them you need to hold the ashtray door half open or just pop the ashtray wood panel facade off. Use a flashlight and you'll see one on each side. Once you undo them, the panel pretty much comes right off. You probably want to use some painters tape to cover any potential inadvertant scratching.
'08 CLK320CDI AMG// '13 E500 Coupe AMG// '17 E350d AMG
removing the wood trim around the radio, theres any way or space to place a gps antena near the vent grills or IC???
I want to install a comand in a friends car and want to know where to place the gps antena...
In the w203 it can be placed behind the IC or near the vent grills, but on the w209 I don't know!
Any info on this?
Any info on this?
I had MbenzNL (Steve) install command in my former 2003 CLK500. And he put the GPS antenna up high, under the dash, behind the instrument cluster (clock, Speedometer, Tach). This provided very good "Visibility" to the satellites.
Of course, he had to remove the instrument cluster to do this, which I don't recall exactly how that's removed. I believe the GPS antenna was flat and was stuck to the underside of the dash with double-sided tape.
2003 CLK 270 CDI AVANTGARDE
That's very interesting, I ordered the new radio with the interface for steering wheel remote and oem display, even if i didnt take it apart yet, I wanted to know if it's easy to go from the radio to the glove compartment, cuz i have to install the navy and the ipod in it...
did it!
its pretty easy... pull off the wood panel at the gear shifter...then the tabs for the ashtray... next the 2 torx screws and pull off the dash...
Now i would be very curious to see how everibody installed a subwoofer speaker, and where you put the amplifier...
then thing is that i had a very cool sound system in my old car, i set up everything to make it a show sound system, and it was pretty good in sound quality competition (EMMA)
But now i want a sound system in order to enjoy my music in the car, and the last thing i want is it be flashy and to modify the original interior of the car..
I didnt have time to take the car apart, i was thinking about taking off the oem subwoofer, make a hole in the back dashboard, and install my jl 10w6 in the way that only the magnet would be in the trunk... I didnt look under the back seat if theres room for the amplifiers like the older mercedes got...
Can anyone light me up??
Thank you!!
Thank you!!
