steering problems and squealing sound when turning at low speeds
has anyone else had any problem with steering especially right after a cold start? The ride seems harsher and i thought it was because the tires were cold but could be something else.
Also, when i turn at low speeds, i hear this squeaking sound sometimes. I read somewhere on this forum it could be a mounting issue.
Can someone help?
w209 clk 500 50k miles warranty expired
Can someone help?
Can someone help?
Can someone help?
1 Post
2003 CLK320
i was under warranty also because I had the extended warranty.
BUt I paid about $750 for bushings, new engine mounts, and struts (or sway bars. I dont remember which one it was.)
I had the same problem. just got it fixed under warranty. I think they replaced the torque strut bushings. hope this helps.
gbahri: are u saying that this was not covered under your extended warranty? what kind of warranty do you have? My warranty is expiring soon, and i'm not sure which one to get.
1 Post
2003 CLK320
did u have any other issues? now my car and steering wheel is starting to vibrate about 60 mph on the highway. Pissing me off...these cars have so many problems
1 Post
2003 CLK320
I love my car.
Besides that I had the car shut off on me in the middle of the road once. Turned out ot be a faulty thing in the gas pedal, but this was recently at 103,000 miles.
Maybe its your tires? They might need balancing and an alignment.
a bit of an update...
took the car to a local mechanic at a gas station near work just to see if i could get a free inspection. I know some dealers charge 70 bucks just to see if there is a problem.
Turns out my rear tires were warped. HOw the hell does that happen? The guy said they were egg-shaped and causing the vibration. Could have been worse i guess. needed new tires anyways.
Now just have to deal with this squeaking issue in the front passenger side when turning after cold starts.
