HELP ME!! my car shake after change air filter
Old Apr 9, 2007 | 06:55 PM
3536707's Avatar
2003 CLK coup
guys help me out..
i just install K & N Air filter yesterday...
after i installed... my engin.. kinda... different.
i guess its shaking...
when i stop my car.... it just shaking..so bad...
did i do something wrong?
or... is it like this... because it is K N air filter... becase of horspower increase?
any advise.... please`~~~~
Old Apr 9, 2007 | 09:03 PM
chixdiggit's Avatar
W209 CLK
Originally Posted by 3536707
guys help me out..
I just finished installing mine and took it out for a drive. The car does feel quicker on the pickup, but I didn't experience any shaking.
Did you snap the airbox back into place properly? I don't think any mod should make your engine shake to the point were it's noticeable while riding in the car.
Old Apr 10, 2007 | 01:35 AM
LB Bnz's Avatar
07 E350, 03 Lexus ES300, 04 CLK 320 (gone)
+1
you may just do a double-check on the fitment of the air box....make sure you tighten the housing which holds the filters, then make sure the entire air box is snug...
the only other thing I can think of if extra oil was added to the filters (which is not required if they are brand new) before installing them...the extra oil can damage the Air mass sensor....
Old Apr 10, 2007 | 09:53 AM
clk22's Avatar
2003 clk55
Your Mass air flow sensor probably went because of the oil in the K&N.
Old Apr 10, 2007 | 10:02 AM
ItalianStallion's Avatar
R35 GT-R, EvoX
Yup, its the MAF sensor. I had the same problem and once I installed a new one it disappeared.
Old Apr 12, 2007 | 09:29 PM
Frisco's Avatar
03 CLK500, 04 X3, No 07 GT3RS :(
Just a guess - maybe you just didn't secure the gasket seal at the back of the filter housing? It takes a bit of muscle to get back on and I would guess that a bad seal might make the airflow highly irregular if it's jumping on and off the seal.
Old Apr 13, 2007 | 12:22 AM
mcdelaug's Avatar
The shaking is caused by misfiring due to inappropriate fuel and air ratios. You need a new Mass Airflow Sensor as others have suggested. Continuning to drive your car with it misfiring could potentially damage your engine, so get it fixed soon.
mcdelaug
Old Apr 17, 2007 | 04:54 PM
clk2k3's Avatar
2003 CLK320, Sliver, Ash Leather, Command System, Xeon lights, K3, K4
I had the same problem when I changed just the airl filter to K&N, it cost me 600$ to fix the stupid problem.
