how many quarts of oil go into clk500? Exact number please and oil extractor question
Old May 8, 2007 | 10:06 AM
dkim's Avatar
2022 911 c4s cab, 2022 Lambo Urus
need to buy an extractor but need to know how big the capacity needs to be.
Found one that's 7.3 liters and dont know if that's gonna be enough. Does anyone know if the extractors need to be as big as the oil tank? Can i just extract in 2 attempts?
thanks
Old May 9, 2007 | 09:44 AM
dkim's Avatar
wow, no one? I lost my manual to the car. No one really?
Old May 9, 2007 | 10:07 AM
Frisco's Avatar
03 CLK500, 04 X3, No 07 GT3RS :(
it's about 8 quarts iirc - I have the big Pela extractor (about $100) and it's big enough to handle two changes without dumping.
http://www.pelaproducts.com/description.htm
Old May 9, 2007 | 11:58 AM
dkim's Avatar
with the extractor, can i stop and start again if it's up to capacity without a mess?
I wanna buy a 7.3 liter extractor and not dish out the extra money for an 9 liter if i can help it.
so can the oil change be done in 2 takes, dumping oil out and starting again?
thanks
Old May 9, 2007 | 12:14 PM
Obsidian's Avatar
thanks
I really don't see any reason what you couldn' t do that. All you would have to do is rebuild the pressure and extract again after you empty out the container.
Old May 9, 2007 | 03:41 PM
FastDonzi's Avatar
'10 c63,'03expedition,ducati999,22'Donzi
i was also thinking of doing my own oil changes but don't have any experience with MB vehicles. where is the oil extractor tube and how do you change the filter? what grade oil do you guys recommend ? thanks
Old May 9, 2007 | 09:49 PM
Frisco's Avatar
Yeah there's no reason you couldn't pump it out in multiple steps if you had to use an extractor with a small reservoir. Obviously you wouldn't want to drive the car anywhere...
You pump the oil out through the dipstick tube, which is located on the passenger side between the engine block and the firewall. There is no actual dipstick because of the electronic oil sensor so the tube is just capped off. The oil filter is located right at the front of the engine block adjacent to the grill - a $2 oil filter wrench from any auto supply place will get it off, and then you just need to pop off the filter and a couple o-rings and make sure that you get the new filter seated properly.
IIRC, the oil is 0W-40 Mobil 1 synthetic but I'd have to look because I don't honestly remember which viscosity it is 100%.
Old May 10, 2007 | 06:44 AM
FastDonzi's Avatar
thanks, that sounds easy enough. how do you reset the service interval computer?
Old May 10, 2007 | 10:20 AM
Frisco's Avatar
Reseting the service interval timer is easy - from the driver's seat navigate to the screen where it displays the service timer and then press and hold in the odometer /trip reset knob to the left of the steering wheel. After 3 secs or so, it'll display a message asking for you to confirm that you want to reset it and you press another button and it resets.
Old May 11, 2007 | 07:05 AM
FastDonzi's Avatar
how do you check oil level to make sure it's not too high or too low?
Old May 11, 2007 | 10:10 AM
Frisco's Avatar
using the digital readout in the speedometer console - scroll through all the menu screens and eventually you will find it
Old May 11, 2007 | 12:15 PM
trikoid's Avatar
09CLK550Cab 61k miles
8.5 liters I believe. They told me to bring 9 liters when I went for oil change, but they said they didn't quite use it all.
John
Old May 11, 2007 | 09:02 PM
FastDonzi's Avatar
thanks guys.
Old May 11, 2007 | 10:51 PM
trikoid's Avatar
Also, my dealership told me to bring 0W-30 Mobil 1 for my 04 CLK 500.
I don't know if that is what all dealerships put in, but that is the one that my New Hampshire (Holloway Mercedes) dealership told me to absolutely use.
Old Oct 22, 2011 | 10:23 AM
ladila2's Avatar
Mercedes 2004 CLK500
Where can I purchase an oil dipstick that will work in my Mercedes 500CLK cabriolet? I realize that you can check the level using the computer but I would rather use a dipstick.
Old Oct 22, 2011 | 03:02 PM
bheng's Avatar
2003 CLK 320
im assuming a dealer.
Old Feb 5, 2015 | 12:08 PM
sjmnt's Avatar
CLK 500 05', 96 C230, 06 Altima
My 05 500 takes 7. Still have the book.
Old Feb 6, 2015 | 04:37 AM
tw2's Avatar
tw2
Old Feb 6, 2015 | 07:31 AM
DanielFD's Avatar
2007 BMW 550i
Originally Posted by tw2
:r olf:
Old Feb 6, 2015 | 06:22 PM
sjmnt's Avatar
Wow. 2007 thread huh. **** happens.
I see the problem. Too much helpy helperton and not quite enough go f*** myself. Adjusting fire accordingly. Also, how long did you have that caption waiting for just the right moment... Lol.
Old Feb 6, 2015 | 06:47 PM
tw2's Avatar
tw2
I apologize, it was quite unfair. I hope you see it in good humor, the forums are supposed to be a fun place. In conclusion the M113 takes way too much expensive oil.
Old Feb 7, 2015 | 12:35 AM
DanielFD's Avatar
2007 BMW 550i
Agreed. Just some guys having fun. No harm meant. Does the 500 really just take just 7 liters though?! My 320 gobles down on 8 L with the filter..
Old Jan 24, 2019 | 09:33 AM
jwb007's Avatar
2005 CLK500
Thank you.
