Guys I need HELP!!
To determine if this is what is setting the alarm off a Star Diagnostic machine can interrogate the system will have information stored relating to what has triggered the alarm.
Hope this helps.
my bet is that it's or siren for the alarm system.
thanks for the info man
If you jack up the front of the car on the left side and remove the front wheel you can see that there is an inner liner (in 3 sections) fixed under the fender. Behind that there is a void in which several components are located, including the alarm system.
So to examine the alarm unit you have to remove either 1 or 2 of these panels... I believe that it has a small back-up battery to make it independent of the main battery.
