2 Quick Questions
Old Aug 9, 2009 | 03:45 PM
v1sionz's Avatar
CLK 500
2 Quick Questions
#1.) Is there any special tools i need to remove the wires off my spark plugs to change the plugs? also is there a post that shows how to do it?
#2.) Were can I get a SprintBooster for my 2004 CLK 500 ?
Old Aug 9, 2009 | 07:58 PM
Supafly's Avatar
I drive the racism out of BadDebt. ;)
17mm open end wrench
check buysell forums and sprintboosterusa.com
Old Aug 10, 2009 | 08:29 PM
v1sionz's Avatar
CLK 500
Just put the wires off by hand?
Old Aug 10, 2009 | 09:48 PM
trikoid's Avatar
09CLK550Cab 61k miles
Not by hand - he is saying to use the open end of a 17mm box wrench to pry it off. No one said it is a pretty process, but supposedly that's how to do it.
Old Aug 11, 2009 | 11:37 AM
Supafly's Avatar
If you pull the wires off by hand, you risk pulling the wires off the coupling...which results in lotta money spent on a new set.
use the open end wrench and pry the cables off using the valvecover as leverage....
or buy the rediculously overpriced MB plugcable remover...something like $80...wtf
Old Aug 11, 2009 | 10:01 PM
v1sionz's Avatar
CLK 500
Ah great thanks for the info guys! : )
Old Nov 25, 2009 | 03:40 AM
CLSXH25's Avatar
MERCEDES BENZ CLK 200 SPORT
HI I AM NEW ON THIS FORUM CAN ANYBODY TELL ME HOW TO CHANGE SPARK PLUGS ON MY MB CLK 200 SPORT 1999(COUPE) ? MY E-MAIL: SALMAN.HAFEEZ@BT.COM
Old Nov 25, 2009 | 04:05 AM
Klinh's Avatar
C63s Cabriolet, BMW M4, Civic
Clk 200 is a 4 cylinder like the Slk 230, C230..etc, right? Just remove the red engine cover, screws and pull the plug wires out with your hand. It so basic that if you need procedure then you should try to do it.
Old Nov 25, 2009 | 07:03 AM
2MCHCAR's Avatar
Supercharged CLK500,ML500,S580
There is currently a group buy going on for SprintBoosters, here's the link:
https://mbworld.org/forums/w211-amg/...group-buy.html
Old Nov 26, 2009 | 12:54 AM
supacrazykev's Avatar
GLE 450 2021, SLK 350 2013, Honda Civc Type R 2019, Suzuki GSXR 750 2014, Ducati Diavel 2018
Doesn't using Touch shift remove the lag from the throttle? Is sprint booster necessary?
-Kevin
