Difference between C and S?
I know C will start out in second gear, but does it change downshift responce or upshift points or anything ?
In reality, the shift point is really no different once you floor it. The only major differences between "comfort" and "sport" is, comfort mode start out in 2nd gear instead of 1st gear.
Transitions are quicker in "S" mode, and even quicker in "M" mode if you have it.
Interestingly, in "C" mode, the car will also reverse using its second reverse gear. (It has 2 reverse gears).
I did notice the other day that the 7-speed gearbox in a 2009 C300 loaner had much better shifts so maybe 2006 was the year for lazy shifting.
Maybe give her a good blast over the next few trips.
See if that changes anything.
Not high speeds and all that.
Make the car regularly change down gears abruptly, as it were.
I don't think there are separate memories though.
I don't use Comfort (or Controlled Efficiency) much either.
I only leave it in "C" until the engine, gearbox & fluids are up to temperature.
Then, straight to "M"!
