Help please
Old Apr 1, 2010 | 03:09 AM
mikare's Avatar
CLK 350
Help please
Do I need to do the wheel alignment after put on the wheel spacer???
I feel a little bit shaking when I drive on the highway over 70 MPH.
The spacers are H&R.
Old Apr 1, 2010 | 04:26 AM
WPOZZZ's Avatar
W211 E55, 911 turbo, 911sc, RX330
Have your wheels balanced. And did you use a torque wrench on your wheel bolts?
Old Apr 1, 2010 | 07:06 AM
dynomite05's Avatar
04 CLK 320 > CLK32K
+1
Old Apr 1, 2010 | 10:38 AM
CLK Masters's Avatar
04 CLK 500, 07 GSX-R 750, S 550, 09 Jeep GC
Originally Posted by dynomite05
+1
+2
Old Apr 1, 2010 | 11:25 AM
dumpsta's Avatar
SLK280(Gone), C63, CLK550
spacers themselves can cause vibration. if the cause is the spacer, some people weld it to the rim.
Old Apr 1, 2010 | 01:25 PM
mikare's Avatar
CLK 350
Before I put on the spacer, there is no vibration.
I didn't put them on by myself.
Old Apr 2, 2010 | 03:24 AM
Klinh's Avatar
C63s Cabriolet, BMW M4, Civic
It NOT the wheels.....it the spacer. You need a spacers with hub centric. A 10mm or thicker spacer will have the lip to center your wheels. 3 mm spacer will still have 2mm hub centric but a 5mm spacer pretty much have very little or no hub centric and cause the wheel not centering onto the hub that cause vibration.
Old Apr 2, 2010 | 10:37 AM
coin's Avatar
'06 CLK500
What size spacers do you have on the car? Are they hubcentric?
Originally Posted by Klinh
.. but a 5mm spacer pretty much have very little or no hub centric and cause the wheel not centering onto the hub that cause vibration.
If they're 5mm, see the thread below:
will 3mm spacers fix the vibration ?
Allignment won't fix your vibration.
Old Apr 2, 2010 | 12:22 PM
mikare's Avatar
CLK 350
The spacer are hub centric spacer.
10 in the front and 15 in the rear.
Old Apr 2, 2010 | 05:05 PM
Mka77's Avatar
06 CLK350 -SOLD! 2010 Cadillac SRX Premium Turbo
I just put my summer wheels and tires back on and was considering the H&R DR series spacers for the rears. 12mm. I think I will watch how this post pans out first. Anyone else have this kind of issue with the H&R spacers? Mike
Old Apr 16, 2010 | 06:50 PM
mikare's Avatar
CLK 350
The root cause is my wheel is not balanced.....
So the problem is gone after I do the wheel balance
