Q's for those with 55K Airbox
Old Apr 6, 2010 | 10:03 PM
2MCHCAR's Avatar
Supercharged CLK500,ML500,S580
I just received my 55K ///AMG airbox and I have a few questions for those of you who have already done the mod on their Non-Kompressor M113 engines.
1.Installation, specifically attaching it to the MAF. I searched the forums for an installation guide for this mod; the best I can find is Klinh's thread here: https://mbworld.org/forums/clk-class...clk-500-a.html . Klinh uses electrical tape to wrap half the tube on the inside and the other half on the outside, then the airbox will fit snug on the MAF. I don't doubt that this method works, but I was wondering if anybody else found an alternative solution to this problem (and if they can share).
2.Air Filters. I was thinking of getting a set of BMC or K&N air filters to go with this airbox. What filters are you guys running with? What were your experiences with them in this scenario? Would you buy them again?
3.Did you guys do any additional mods to these airboxes? For example, I heard of people dremeling out the ribs on the inside of their M113 500 airboxes in order get more air flow (I haven't opened these airboxes to see if they are in here too).
Thanks for the input!
Old Apr 7, 2010 | 12:42 AM
omar26's Avatar
E55
1. Blackbenzz helped me put mines on and I was told to use permatex sealant and it fits snug on the maf. Whenever I take it to the dealer they never have a problem taking it off and just clean it up and put another layer of sealant for me. Make sure you cap off the little hose on the back side of the y-pipe.
2. I used K&N filters, but some people said the amg filters are better than the k&n filters. I cant tell much difference.
3. I'll probably dremel out the fins on the inside this weekend now that you mentioned it. I used heat shield tape on the bottom of the air boxes to keep the air cooler. I also bought the kevlar air intake hoses from the newer 550 models.
Old Apr 7, 2010 | 01:08 AM
Klinh's Avatar
C63s Cabriolet, BMW M4, Civic
Originally Posted by omar26
1. Blackbenzz helped me put mines on and I was told to use permatex sealant and it fits snug on the maf. Whenever I take it to the dealer they never have a problem taking it off and just clean it up and put another layer of sealant for me..
To much works, too messy plus don't you have to wait at least 30 mins for the sealant to dry before use? My suggestions is, try both ways and see what you like best.
Old Apr 7, 2010 | 08:43 AM
sweet jones's Avatar
W209, E46 M3 (dead), S54 swapped E46 Touring
pics of said hoses? and maybe part numbers if available
Old Apr 7, 2010 | 10:10 AM
advans's Avatar
C55 ///AMG, 535xi
1. You'll need to flip the Y section hose left and right, and put eletrical tape on the inside of the Y section to fit snug on the MAF.
2. I think Stock filters are fine, the K&Ns or everything else clogs up very quickly.
3. Theres nothing to dremel out, the 55k boxes has no fins! what you can do while ur box is off, PAINT it.
Old Apr 7, 2010 | 11:03 AM
omar26's Avatar
E55
Well I guess i wont be doing that then
Old Apr 7, 2010 | 11:46 AM
advans's Avatar
C55 ///AMG, 535xi
^oh right, you should get the kevlar tubes as mentioned.
I'm still trying to figure out if I can build new, larger tubes with fiberglass and a mold!
Old Apr 8, 2010 | 07:07 AM
2MCHCAR's Avatar
Thanks for the input guys
So here is my checklist:
* Use the stock MB Air Filter
* Add heat shielding tape on the bottom side of the airbox
* Paint it
* Get Kevlar tubes from a CLK550
* Get the engine cover from another ///AMG
Advans/omar26,
Do you know the part numbers for the 550 Kevlar tubes? I tried to go to parts.com and search but they had only two kinds.
1. For the 63 engines
2. For the non-63 engines
My assumption is that the 350 and 550 engines use the same air intake tubes. Is that correct?
Klinh/All,
Which ///AMG engine cover (Model/Year) did you use to match the airboxes, in order to dress up the engine bay?
Old Apr 8, 2010 | 10:32 AM
omar26's Avatar
E55
A273 090 01 82 (left) A273 090 00 82 (right)
Old Apr 8, 2010 | 10:39 AM
omar26's Avatar
E55
* Paint it
Advans/omar26,
Klinh/All,
I think some people used the engine cover from the 63 engine. I used the 55 engine cover and it fits w/ little modification. The tubes are 30-40ea at the dealer.
Old Apr 8, 2010 | 11:15 AM
FatTony001's Avatar
CLK 55 AMG 2005 and CLK 63 AMG cab.2007 - 2009 EVO - 2013 ML63 AMG - 2018 G63 AMG
any picture of your set-up Omar ?
keep us updated 2Much
Old Apr 8, 2010 | 12:20 PM
buffyclk500's Avatar
clk500
Post if u fell a power dif
Old Apr 8, 2010 | 09:15 PM
omar26's Avatar
E55
I got pics b4 I put the engine cover on tht i'll post up.. I'll get the current setup pic this weekend for you.
The SL is so damn heavy I dont think I'll notice a power diff unless I do something big like headers.
Old Apr 9, 2010 | 08:48 PM
advans's Avatar
C55 ///AMG, 535xi
surprisingly the car drives better now in hot weather.
I used a e55k setup even the oem engine cover, sits nearly perfect, I'll post pics when I get a chance
Old Apr 9, 2010 | 10:35 PM
2MCHCAR's Avatar
Can't wait to see your setups! I think I'll order the 55K engine cover like you guys did to cleanup the engine bay.
Advans,
On an earlier post, you said "You'll need to flip the Y section hose left and right". Just to clarify, this means put the left Y-pipe tube on the right side of the Y-pipe and put the right Y-pipe tube on the left side of the Y-pipe; "flip" the positions?
Old Apr 10, 2010 | 07:59 AM
dynomite05's Avatar
04 CLK 320 > CLK32K
Advans,
Where you ordering the cover from?
Old Apr 10, 2010 | 09:00 AM
2MCHCAR's Avatar
I'm planning to get the ///AMG cover at parts.com, plus the 550 Kevlar Tubes and MB Air Filters.
Old Apr 10, 2010 | 08:34 PM
advans's Avatar
C55 ///AMG, 535xi
correct left y tube on right, right y tube on left
Old Apr 10, 2010 | 08:55 PM
Klinh's Avatar
I sold my 1st E55 air box with Clk 500 front cover. I modified the cover a little bit and it fit perfectly flat. I posted some pics.
Old Apr 10, 2010 | 10:20 PM
advans's Avatar
C55 ///AMG, 535xi
^I mean I have the OEM E55k box, I bought the whole setup, with the E55k front cover
Old Apr 21, 2010 | 12:40 PM
advans's Avatar
C55 ///AMG, 535xi
finally got a chance to take some pics of the airbox
Old Apr 21, 2010 | 12:46 PM
M-bENZ's Avatar
Corrolla
still have your stock air box ? let me know.
Andy
Old Apr 21, 2010 | 08:13 PM
clk500
If u need a stock 1 I got 1
Old Apr 21, 2010 | 08:57 PM
M-bENZ's Avatar
Corrolla
I need the one from C55 .
Andy
Old Apr 21, 2010 | 09:16 PM
clk500
Well the 1 I got I cut all the fins out but it does not look as nice so your call
