first time posting pic of my car, H&R springs lowered and new wheels
Old Apr 10, 2010 | 07:59 PM
ts350z's Avatar
S550
Just finished dropping the front and still need to work on the rear,will post more pic after the rear is done. The front took about 2 hours without any air compressor tool. Just used the cheap $40 Autozone spring compressor to do the job. Thanks again for the advice and help from the forum ;P
(front lowered with H&R springs & Koni shocks)
(Before the dropped, about 3 fingers gap on the front)
Old Apr 10, 2010 | 09:29 PM
andy_meng1024's Avatar
2003 SL55, 2010 C63
Looks good. I wish I could've done this myself so I could save $400 every time I have someone else does the job for me.
Old Apr 10, 2010 | 09:55 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
+1.
Looks good..Love the wheels! I'm getting the same ones!
Old Apr 10, 2010 | 10:55 PM
M-bENZ's Avatar
Corrolla
looks like we have the same colors (the car) ...is your pewter silver ? By the way, wheels looks good.
Andy
Old Apr 10, 2010 | 11:10 PM
kevblah's Avatar
E90 M3
i want to lower my car, but question myself as to whether i have the skill to change out the suspension myself. would having a lift help at all? what other tools would i need?
Old Apr 11, 2010 | 02:46 AM
ts350z's Avatar
S550
You don't need the car lift to do the job. If you have experience with Nissan, Honda or Toyota. Then you can do the suspension here. Last time I dropped the car was on my Nissan 350Z. It's not too much different. Once you figure out how to take off the front upper mount of the shocks then the rest is easy. I think the CLK is really simple to take the shocks / springs off the car compare to many other car. Lots of space to work with too.
First front suspension took me prob. over 1 & half hour, the second one less than 30 mins...., I looked at the rear suspension, it seems really easy. I will prob. do it when the weather is cleared up tomorrow.
And yes, my car is pewter color
Old Apr 28, 2010 | 01:15 AM
pinoytm's Avatar
-=[CLK 500 2006]=- -=[Dodge Ram 2001]=- -=[Kawasaki Ninja 636 2005]=-
I was surprise you were able to jack the car on that little side... doesn't it comes with plastic beneath the car? I tried jacking mine and I couldn't find any good spots... my previous cars civic does not have any plastic beneath it! LOL... how much are those wheels? looks tight! and would you mind telling me how does the fog light works? it lights up by itself when i try moving the wheels left to right... sorry its my first luxury car.. funny thing is that it took me few days to open the hood too... its not like Japanese cars that everything is straight forward...
lastly... good job on dropping it yourself.. i will try to do it to mine too if I figure it out!
Old Apr 28, 2010 | 02:47 AM
Klinh's Avatar
C63s Cabriolet, BMW M4, Civic
The rear are very easy. If you do it at home, depending on how high you can jack up your car off the ground. If it high enough, you can just remove the control arm bolt from the drive shaft spindle knuckle. If it not high enough, the control arm will not drop down far enough for you to remove the springs. I preffered to remove the inner control arm bolts (the bolt that hold the control arm to the middle of the chassis) because it allow the control arm to fully lower to the ground more. Btw, use the hydrolic jack and place it under the control arm to lower the control arm when you remove the bolts. It very very easy job. As you already know, the front strut is very easy like any other car struts. The only difficult on the Clk were finding the right tool to remove the plate locking "ring". I hand made the tool for that.
Old Apr 28, 2010 | 11:01 AM
ts350z's Avatar
S550
Dropped the rear about a week ago, I added the 5mm wheel spacer. Rear wheels are more flush to the fendor ;P I ordered the new rear spring pads. I bought the 13mm and 17mm one, will try them both and see which I like more. The front wheel fendor gap seem kinda big still.
Old Apr 28, 2010 | 12:31 PM
BadDebt's Avatar
2008 ML550 P2. 2010 E350 P2
good looking car. Ride feel any diffrent with the spacers?
Old Apr 28, 2010 | 12:33 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
You think you could fit 10mm spacer in the back?
Old Apr 28, 2010 | 12:39 PM
ts350z's Avatar
S550
I would like to have the 10mm spacer in the rear. I will try them out this weekend. I ordered the 10mm & 8mm spacer. We'll see how it turns out !
Old Apr 28, 2010 | 01:13 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
Yes please keep us posted, I still haven't ordered them
Old Apr 28, 2010 | 10:58 PM
Klinh's Avatar
I'm using 3mm front and 10mm rear.
Old Apr 29, 2010 | 01:32 AM
pinoytm's Avatar
ahhhh so nobody answered my n00b question....
Old Apr 29, 2010 | 06:32 AM
dynomite05's Avatar
04 CLK 320 > CLK32K
Which question?
Old Apr 29, 2010 | 07:04 AM
Bob Loblaw's Avatar
2005 CLK 500 Cabriolet
Okay, you changed the springs and struts, I'm guessing from your sig that you put the bigger rims with rubber bands for tires. :-) The car looks great but I'm wondering how does it ride? When I did similar work on my BMW it looked great and handled great but the ride was pretty rough. Bumps were harsh and eventually noisy from things being jarred loose. It was a lot of fun at first but after a while it got tiresome. Too race car. I'm wondering what yours is like.
I'm also wondering what your purpose is in doing the suspension mods. Are you tracking the car?
Steve
Old Apr 29, 2010 | 10:51 AM
ts350z's Avatar
S550
I'm also wondering what your purpose is in doing the suspension mods. Are you tracking the car? Plus I need to find the time to install my Kleemann super charger, it's been sitting here in my living room.
BTW, I only take my CLK out when the weather is nice, I ususally drive my S550 for work daily. So it's fun to have something sporty on the weekend. ^^
Steve
The ride is totally fine, I would say it's pretty smooth for the setting I have. As for the purpose of the suspension... ? hmm I'd say I just like to mod the car for the look and handling. I don't care for track or racing, it's just something to have when I wanna take a sharp coner
