New wheel trouble
btw, what's the original bolts lenght?
my solution to my problem is either running a 255 tire or going with a 6mm spacer.
I'm not sure how short the bolts can be while still being safe. All I know is the max length of thread that can be sticking out. Perhaps you don;t need a longer bolt if you reduce the thread by only 2mm, but I'm not sure.
The rear looks good to me, don't like the sunken look of some bigger drops but the front is a bit too high. Will take some pictures later and post them.I did have a bit of I hope temporary problem with the rears. On the first test drive I had what sounded like a rubbing sound coming from the passenger rear. Inspecting closely again I did not see any space issues and could not figure out where the sound was from. It was in and out as the wheel turned and was not very loud. Its hard to see behind the wheel as there is not much room to stick a hand in and I can hardly get my head under the car but it definitely has plenty of room as far as I can tell. I had my wife drive the car the next day while I was walking along and the sound was gone. Did maybe 20 min of test driving at varies speeds and all sounds good. No idea what the hack it could have been. Maybe something to do with the e-brake not releasing completely on the first run? I engaged and unengaged it a few times after the initial noise.
As for the ride, its definitely stiffer but not more noisier then the OEM with the winter tires. The Winter tires did sound louder and stiffer then the OEM all season tires which is normal. I have not done any higher speed cornering at this point.
Existing setup stand like this:
Front: 19x8.5 32mm offset with 225/35/19 Toyo FZ4 tires, 3mm spacers, 24mm bolts
Rear:19x9.5 35mm offset with 255/35/19 Bridgestone Potenza RE050 tires, no spacers, 24mm bolts
On the fronts with no drop going with a bit wider 235 tires I think would look better. Original owner of these rims had the car dropped with Eibach springs and according to him these Toyo 225 wide tires were chosen do to the side wall angle to eliminate or reduce the chance of rubbing on some turns.
Hopefully I'm now good with the wheels and can move on to my next stage of mods and that is getting the OEM AMG bumpers painted and installed
Now the only thing left is getting this threw the wife with out a fight
By the way, did you vinyl the roof or is it painted? This is exactly one of the mods on my list. How much did it cost?
It's basically a 4x4 now on the front. I don't mind the back as I'm not a biggest fan of a tucked in look but the front is quite bad now.
Sorry for the bad pictures, it was taken with a small camera in bad light. I need to drag out my SLR and take some pictures outside in the sun (when we get sun back in Chicago).
I run stock springs with Bilstein HD shocks/struts. My wheels have a et35 offset and found that my front wheels would rub against my shock when I turn and reverse (or do really high speed cornering
). I added a 3mm spacer and it solved the problem.
I do need the drop and bigger brakes once I get my AMG bumpers installed
My fronts are ET32 and rears ET35. I'm running 3mm spacers on the front and will add 3mm spacers in couple days just got to find the time to do it.
Did you have stock none AMG or AMG spring, I think they are deferent? How do you like the ride quality comparing to stock shocks? I guess the ride did not get any lower with the stock springs? You do look lower then my.
Also what was the reason for the Sway bars? was the camber so bad?
https://mbworld.org/forums/clk-class...installed.html
In a nut shell, I tried to lower my car with H&R springs, but I wasn't too happy with the setup. I decided to leave the Bilstein shocks/H&R sway bars in and I noticed my handling improved greatly (My friend drives a stock 2004 CLK55 and we both agree my car handles better
).Do you remember where you got your Bilstein shocks/struts and approximate cost for all 4?
Darius
Darius
