Roll down all windows and sunroof
-=[CLK 500 2006]=- -=[Dodge Ram 2001]=- -=[Kawasaki Ninja 636 2005]=-
Does anybody know or is it possible to roll down all windows and sunroof with a touch of a button inside the car?
I know that you can roll it all down using the remote... but the funny thing is that sometimes it works and sometimes it doesn't so I look like crazy trying to press/hold the unluck button and POINTING it to the IR on driver side... LOL![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
I also know that the air circulator can make all windows close wheny you press and hold it... but I need a button to open all windows... anybody knows?
damn! lol... is there a way to enhance the remote then? I kept imagining how do I look like when I try to roll all windows down using my remote! maybe a person trying to change a TV CHANNEL using a dead battery remote! LOL
GLE 450 2021, SLK 350 2013, Honda Civc Type R 2019, Suzuki GSXR 750 2014, Ducati Diavel 2018
i have the same problem with the key remote.. Sometimes it doesn't work
![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
04 CLK 320 > CLK32K
It's a little buggy...I was playing around with the key remote the other day and this is the conclusion I came to.
To bring windows down I have to hold the button at the same time I unlock the car. In other words it didn't work for me when I unlocked the car then tried to roll down the windows. The same thing for putting them up. If I hold the button while the car is locking they will go up. Locking it first then holding the button it didn't work.
Someone mentioned some add on available in Germany to allow this but I can;t remember the details. It was on this forum I think
That is what I am saying here... lol... the remote makes you look stupid! I just tried to do it with my friend watching me and guess what? IT DIDNT WORK! LOL...
I think the main issue is the IR in the driver side handle...
![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
me: 2015 SL400 & 2015 ML400; wife: 2022 GLC Coupe kid: 2017 GLC SUV
The remote, which I seldom use cuz it's so fussy, is intended for cooling a hot car before you get in, or buttoning one up when it starts to rain. Really, a different application altogether. I think the fussiness is related to the key being both IR and RF: that feature only works IR (like the trunk), so it requires a pretty close line of sight.
2005 CLK 500 Cabriolet
http://www.cartronics.com/MBMost.htm...1&IntelliTop=1
I installed this in my car to do exactly what you wanted. Now when I touch the top up/down button once, my windows all roll down and the top goes down with the added benefit that I can do it in drive while moving down the road. It will also close everything if you start the process with the car on and then shut it off and get out of the car. The remote works a bit different than normal since it uses the radio control part of the remote to control the operation. Hitting the unlock button three times one second apart will also open the windows and top from door unlock distance rather than standing next to the car holding down the stupid button. It's my favorite mod.
Steve
Oops. I thought you were asking about a cabriolet. I don't know if the intellitop will work for the sunroof but you can write the company and ask about it, I guess.
Steve
I’ve a 2006 w209 and the only way it works is with the remote control touching in the IR square.
If I maintain the button pressed down and move away a little bit it stops working.
The batteries are new one (CR2025).
I don’t know if it work this away for security reasons, but I still prefer VW Golf method: you close/open your windows even from China!!
'05 CLK55, '04 CLK320
I believe the reason why sometimes the windows go down and sometimes they dont depends on the weather. The day they didnt go down was probably because it was a cooler day
oh man thank you. I thought i was crazy believing that. It does the same to me but i thought it was a coincidence lol
2012 CLS 550 Launch Edition, 2004 CLK 500, 2004 Honda Civic
Ok now I'm just in a bad mood...lol...all the windows roll down and up with the re circulation button except for the drivers side rear...I can't figure it out!...any ideas?...
Angelo
Angelo
2018 E43 | 2017 GLS450 | 2004 CLK 500
you might have an issue. My recirc button works fine. There's another button that will open/close all windows but I forget which one it is. It's in the manual.
Also I've found that the remote doesn't work if you are either too close or too far from the IR sensor.
i just tried it on my car last night trying to impress my wife with the benz since she is an audi girl, but it failed to impress her. i had the a/c on and i kept the recirc button pressed for 10 seconds and nothing. so then i pressed it again, but nothing happened. all my windows were closed at the time. tried it on park and drive, but no luck!
When some windows close and others don't or if nothing happens when recirculation button is maintained, it's because you need reset windows.
Close it all manually and hold close position until you heard a relay sound.
can you find this buttion? this is what the original poster is asking about. Im not sure if there is a button to press to have all the windows come down when they are up
