Mileage survey
Old May 17, 2010 | 12:37 PM
supacrazykev's Avatar
GLE 450 2021, SLK 350 2013, Honda Civc Type R 2019, Suzuki GSXR 750 2014, Ducati Diavel 2018
Mileage survey
How many miles do you guys have now and what year is your car. What kind of problems have you guys experienced with your car?
I have 45k on my 06 clk350. So far MAF sensor and power steering failures.
Just interested about the future of my car.
Kevin
Old May 17, 2010 | 12:46 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
68k on my 04 CLK 320...Only real big problem I had was at 60k miles that my alarm would randomly go off. Dealer replaced with brand new system.
Old May 17, 2010 | 12:48 PM
M-bENZ's Avatar
Corrolla
61K (CLK500-05) at the clock...right now its perfect lolz.
Andy
Old May 17, 2010 | 12:55 PM
BadDebt's Avatar
2008 ML550 P2. 2010 E350 P2
04 500 w/ 71k no problems since my ownership ( purchased w/ 52,000 miles 2 years ago)
Old May 17, 2010 | 01:39 PM
bheng's Avatar
2003 CLK 320
03 CLK 320 with 76k on the odo. i had my transmission replaced under warranty.
and also had a passenger seat problem that continually needs to be fixed. lol until i just gave up.
Old May 17, 2010 | 02:48 PM
guofan's Avatar
W209 500
05 CLK500 with 72k, one side of my valve cover is leaking. The dealer sealed it instead of replacing it. The dealer also replaced the turn signal and third brake light right before the warranty ended. Besides that and regular maintenance, nothing else. I got the car 2 years ago with 29k. I drive a lot and value went down like sh!!!!!!t
Old May 17, 2010 | 03:07 PM
M-bENZ's Avatar
Corrolla
dang you drive 40k miles in 2 years ? wow lol.
Andy
Old May 17, 2010 | 03:26 PM
dark knight's Avatar
04 CLK500
04 CLK500 purchased 09/2007 at 43K, now at 72K.
No problem to speak of except when I topped off with a generic coolant causing leak to transmission oil. Luckily got the trans rebuild under warranty, would have cost almost $8K.
Also the third brake light cover broke, DIY fixed, now looks better than stock.
Old May 17, 2010 | 03:37 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
What do you mean by "looks better than stock"? You didn't replace it with an OEM light?
Old May 17, 2010 | 04:57 PM
johny1989's Avatar
clk v6
i drive a lot
160 000 km
still felling like new .
Old May 17, 2010 | 05:15 PM
04 CLK500
I kept the original LED lights and the housing, just broke off all the plastic pieces. The LED is lit red already; so, clear plastic ruler from Walmart $3, sand and polished off the numbers, 1 hr of drimmel tool and sand paper shaping it to fit, 3M double tape $6, make sure it's air tight so no condensation. Voila, one of the kind. Priceless!!!
I'll try to post picture later, it sparkles.
Old May 17, 2010 | 05:19 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
Sounds like an interesting DIY, would love to see how it looks!
Old May 17, 2010 | 10:59 PM
riarm's Avatar
03 CLK 500
Bought mine with 47k miles . Right at 93k mileS- runs like champ. No issues
Old May 18, 2010 | 05:01 AM
icecream's Avatar
W211 E55 - W209 CLK (gone)
52.5 right now. bought it with 45k
Old May 18, 2010 | 11:48 AM
FastDonzi's Avatar
'10 c63,'03expedition,ducati999,22'Donzi
'03 with 126k. bought it with 26k, four years ago.runs great. changed the drivers door control module last year,and the mass air sensor twice,once at 50k and now at 125k.
Old May 18, 2010 | 12:19 PM
pinoytm's Avatar
-=[CLK 500 2006]=- -=[Dodge Ram 2001]=- -=[Kawasaki Ninja 636 2005]=-
when are you doing next service? lemme know how it goes.. im about to hit 60k too!
Andy
Old May 18, 2010 | 12:25 PM
guofan's Avatar
W209 500
I thought i drive a lot. But you beat me.
Old May 18, 2010 | 12:26 PM
pinoytm's Avatar
2006 CLK500 - 58k valve seals problem! took it to a MB independent shop and spent $480 does not even have a CA plate yet! LOL
I just hope this is just it for now!
Old May 18, 2010 | 12:29 PM
guofan's Avatar
W209 500
what did they change for $480?
Old May 18, 2010 | 01:20 PM
pinoytm's Avatar
just to re-seal the valve seal! lol... when I called then they quoted me for $580 to replace the engine mounts... coz that's what I know or the advices I got from here... but they said engine mounts was okay... so they are going "DEEPER" lol... and said it was the valve seals...
valve seal costs $80 and labor is $400 lol
they did not even replace the valve seal! they just re-seal it... tsk tsk...
Old May 18, 2010 | 01:23 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
If they didn't replace the valve seal then why did they charge you $80 for it? Shouldn't it all be labor?
Old May 18, 2010 | 01:28 PM
pinoytm's Avatar
that's what im sayin... I checked on ebay the valve seal.. it was around $86 so if I knew that it was the problem I could have done it myself! lol...
and yes... the guy said he only re-sealed it... but before that.. he said... he did a lot of diagnoses like computer and blah blah... that is why it is $480
lol...
Old May 18, 2010 | 01:29 PM
dariusf's Avatar
2023 CLA 250, 2021 GLC43, 2003 CLK320
Got my 2003 CLK320 a year ago with 30k miles. Now I have huge 33k miles on it
No major issues other then the radiator leak causing the trans failure resulting in replacement of the radiator, transmission and torque converter. Then one of the turn signal modules died on me so had both replaced. Also had a rain water leak to the trunk threw the trunk gasket that I patched up and one of the sockets in one of the rear lights had connection issues so I cleaned that. I'm also hearing a faint whining noise from the left side of the engine compartment so it sounds like one of the pulleys maybe going bad. Its on and off so hard to debug. Also the rain sensor is massed up having hard time deciding the speed at times
Other then these 'little' issues its running great
Old May 18, 2010 | 01:30 PM
pinoytm's Avatar
lol
Old May 18, 2010 | 01:33 PM
dariusf's Avatar
lol
come on, thats whole 250 miles, a month my other car is a train
