Someone should tell Oliver to join the thread..lol
Quote:
i still don't understand what the fuss is all about.... this is a very simple tune, and very safe it's not maxing out our cars out put.
Originally Posted by badblackbenz550
dont quote me on the 1500 i had that that on my other car, i dont even think oliver will raize the limiter, all he is doing is mixing more air and gas in to the engine over the factory mixture.i still don't understand what the fuss is all about.... this is a very simple tune, and very safe it's not maxing out our cars out put.
The basic tuned on a stock engine is by advance the timing a little bit to lean out the air fuel ratio and that why everyone reported better gas mileages.
As for safe (i'm not sure) because of known air fuel ratio after tune and do they unsolder the chip to do the tune with cars that have the ECU on the top of the engine and not max out the car, (in term of power)I agreed. Since NO ONE ever shown any real world dyno after tuned, I don't know what the air fuel ratio at with the tune. The stock engine air fuel ratio is around 12-12.5:1. With the ECU tuned, it still safe if the air fuel ratio around 13.0-13.5:1. Anything higher then that would reduce the life of the engine in a long term because the engine combustion temperature is risen and heat will wear parts out much faster. Btw, fuel is not just for burn inside the engine but also acted to cool the engine.
Quote:
my point.... power chip does the same exact thing for $1500 Originally Posted by Klinh
Quote:
I hope not, that's why i wish Oliver was on this thread to make things more clear since it seems the people getting the tune are not sure either. Originally Posted by Klinh
No one is that stupid to risen the rev bu 1500 rpm on any stock engine. It normal to risen it by 500 rpm.
Has he given you any kind of info on what the tune is? If so our answer will be on there...if not i'd be nice to see if he's raising it at all or by 1500...makes a big differences it seems. Originally Posted by badblackbenz550
Quote:
+5. Never knew he was on the forum.Originally Posted by dynomite05
Hopefully Oliver can join this thread and answer some Q's for us that need answers. If not i'm sure BlackBenz will get some kind of info on what Oliver did to his ECU when he gets it back? I'd assume? Originally Posted by Klinh
The basic tuned on a stock engine is by advance the timing a little bit to lean out the air fuel ratio and that why everyone reported better gas mileages. As for safe (i'm not sure) because of known air fuel ratio after tune and do they unsolder the chip to do the tune with cars that have the ECU on the top of the engine and not max out the car, (in term of power)I agreed. Since NO ONE ever shown any real world dyno after tuned, I don't know what the air fuel ratio at with the tune. The stock engine air fuel ratio is around 12-12.5:1. With the ECU tuned, it still safe if the air fuel ratio around 13.0-13.5:1. Anything higher then that would reduce the life of the engine in a long term because the engine combustion temperature is risen and heat will wear parts out much faster. Btw, fuel is not just for burn inside the engine but also acted to cool the engine.
Quote:
1. Badblackbenz550 (Sent check)
2. BadBlack550 (sent check)
3. dariusf (Sent check)
4. Dark knight (sent check 7/7)
5. Driver9 (Sent check)
6.jho012345( sent check)
7.hoopy82 (sent check)
i have taken out people that are slowing us down, i have contacted them over the phone and left pm's
Is this is most up to date list we have? I'd be willing to pay an extra couple dollars or so per tune & just get this over with...what do you guys think?1. Badblackbenz550 (Sent check)
Quote:
Sure, how much more?Originally Posted by jho012345
ExploreJunior Member
Just want to verify - I have a 2005 clk500 cabriolet - what is the GB price? If it's $199 I'm in for sure. Where do I send the check?
Steve
Steve
Check to see If your ECU is up top or on the side
That's the problem. I don't know how and I figured all 2005 clk 500 cabriolets would be the same. So how do I do that? What am I looking for?
Check a couple pages back. Either the ECU is on top of the airbox or it's on the drivers side inside the box of fuses. Check out page 1 of this thread and you will see the OPs pic of the ECU on the side.
Quote:
Bob, I also have an '05 CLK Cab, and the ECU is on the side. The tune is $199 for us.Originally Posted by Bob Loblaw
I would like to know more about the air/fuel mixture, dyno charts, and RPM limiters. If everything looks on the up and up, I have 2 clk500s that may be in.
Also want to know if this affects throttle response. In other words, does it make sense or is it foolish (repetitious) to run with a sprint booster?
I have been running it with a sprint booster for a few months now with no problems.
Quote:
Steve
2203 Spencerville RoadOriginally Posted by Bob Loblaw
Just want to verify - I have a 2005 clk500 cabriolet - what is the GB price? If it's $199 I'm in for sure. Where do I send the check?Steve
Spencerville, MD 20868
USA
Make sure to Include your forum name, and PM me your info:
Real Name:
Forum Name:
Phone:
Address:
Email:
Ecu LOcation:
USA
Real Name:
Forum Name:
Phone:
Address:
Email:
Ecu LOcation:
2203 Spencerville RoadSpencerville, MD 20868
USA
Real Name:
Forum Name:
Phone:
Address:
Email:
Ecu LOcation:
How do we send deposit for the programmer? Will that be a second check later on after this finally closes, then would we have to wait for it to not be needed in the shop, then mail it back, then wait for a check to be returned?
Would paypal be an option so we could shave 3 weeks off this process??/
From what I understand the deposit can be via PayPal
I did it through paypal.
Darius, my mechanic has been a little backed up, I didn't forget about you. Don't mean to hold you up, I should have it this week hopefully.
once you send in check or money order for the tune, and once Speed tunin g has all 10 payments from everyone, he will contact you in the order the check ware received then you can deposit 500 via paypal and the tuner will be shipped out to you, once you ship programmer back the $500 deposit will be released back to you. Originally Posted by whalermax
How do we send deposit for the programmer? Will that be a second check later on after this finally closes, then would we have to wait for it to not be needed in the shop, then mail it back, then wait for a check to be returned? Would paypal be an option so we could shave 3 weeks off this process??/
Hey Badblackbenz550, any word from Oliver regarding a slight price increase for all of the members who have paid already? Thanks!
Quote:
dude just call oliver and tell him...this is it..take it or leave it...its a tough economy...he would be a fool to say no...Originally Posted by jho012345
