clunk from rear
Old Jul 20, 2010 | 10:26 AM
saltydizzle's Avatar
2005 E55 AMG; 2005 CLK 500 (sold)
clunk from rear
hey guys, from a stop, when i accelerate hard, i hear a clunk from the rear. its only from a stop and only when i get on the throttle. under normal driving conditions, or accelerating slowly from a stop, there is no noise. anyone know what this could be? My coilovers are practically brand new and if its the shocks ill be pissed. any help is appreciated as always. Thanks.
Old Jul 20, 2010 | 12:17 PM
Jjwilbs's Avatar
2009 clk 350 cabriolet
i took my 350 to the mb dealership over this - i left a water bottle in the boot - oops!
Old Jul 20, 2010 | 12:34 PM
bheng's Avatar
2003 CLK 320
i would suggest the same. anything loose in the boot? or back seat. i left a can of window cleaner and when i accelerated hard it made a clunk.
Old Jul 20, 2010 | 12:39 PM
hmmm i had my snow removal tool back there. im gonna take it out and see if it stops this afternoon. thanks guys.
Old Jul 20, 2010 | 01:22 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
When I switched my tail lights I completely took apart the trunk lining...You wouldn't believe some of the stuff I found rolling around...Definitely take some time and lift the liner to see if anything is back there...Maybe something is loose
Old Jul 20, 2010 | 01:49 PM
ok cool...i will check that out tonight. Thanks wes.
Old Jul 20, 2010 | 01:57 PM
M-bENZ's Avatar
Corrolla
make sure u dont have cans rolling around in your trunk or personal stuff laying around it will caused the noise...
Andy
Old Jul 20, 2010 | 03:08 PM
yeah i think it might have been my snow removal tool that was hitting the trunk. Im gonna check that after work as well as lift the liner as dynomite suggested
Old Jul 20, 2010 | 06:08 PM
Ok so I removed the snow removal tool and have nothing else in my trunk. I lifted up the lining and there is nothing. I do have my spare and all equipment in there. Could that be the source of the noise?
Old Jul 20, 2010 | 06:15 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
I had stuff rolling around the sides by the amp. There is a pocket there were things gather, have you checked that?
Old Jul 20, 2010 | 06:21 PM
Yeah the only thing in the right side pocket was a piece of zipper that I just found. Other than that nothin.
Old Jul 20, 2010 | 06:27 PM
bheng's Avatar
2003 CLK 320
i would put my money on the snow removal tool for the reason causing the noise. Mercedes actually has good dampening for the stock sound system. they have a layer of dampening on the doors.
but only way to find out is to floor it and see =D
Old Jul 20, 2010 | 07:27 PM
Well I can tell you guys it's nothing in my trunk making that noise. I believe it's the rear suspension. If I put enough preside on the rear it "knocks". ****in brand new suspension and I already have to go to the shop. Again.
Should say pressure not preside
Old Jul 20, 2010 | 07:34 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
Ouch! I feel for you man...Lets hope it nothing serious or maybe the camber kit and not the suspension
Old Jul 20, 2010 | 07:37 PM
Yeah i was thinking it could possibly be that too. I really hope that's the case and it's not the suspension.
Old Nov 2, 2010 | 09:31 PM
camerri's Avatar
CLK 550 Cab
Okay, so you may have gotten this problem fixed already and if so, great. However for anybody else searching through here with the same problem I thought I would give the resolution the dealer did for me with my similar problem.
I had the exact same clunk and squeaky noise from the rear of my car. The clunk happened at low speeds and either over speed bumps or going around a corner up hill at low speeds. Sounded kind of like metal on metal. So I took it into the dealer and luckily on our test drive I was able to reproduce.
The squeaking noise was the rear sway bar link arm and they replaced it under warranty, the clunk was an unseated spring in the rear. They re-seated and rotated the spring and now no noise. Not sure if this is your problem or not, but it's worth a shot.
Good luck!
Old Nov 4, 2010 | 10:41 AM
2MCHCAR's Avatar
Supercharged CLK500,ML500,S580
Good luck!
I'm having a similar problem, thanks for sharing your experience. I'll update the tread when I have my problem figured out.
Old Dec 14, 2010 | 09:21 PM
gaiex's Avatar
'13 E500 Coupe AMG// '17 E350d // '24 E53 AMG
I also have KW V2 and started to have a vibration on the rear when passing the 3000rpm!
Checked all the suspension, even teste the shock on a shock tester machine and they look to be ok , only a 2 % difference from left to right at the rear.
Don't know what to do... will leave the car at the dealer to check engine and transmission mounts...
Old Dec 14, 2010 | 10:11 PM
FastDonzi's Avatar
'10 c63,'03expedition,ducati999,22'Donzi
guys,i also have some clunking going on back there.it seems to me that when you lower and stiffen the car things wear out much faster.a thorough investigation of the undercarriage by my mechanic reveled collapsed cross member mounts.makes sense
Old Dec 15, 2010 | 03:57 PM
hmmm that vibration is weird....i have never had anything like that with my KW V2. But my clunking noise also has gone away for quite sometime now. I think it had something to do with when the car was lowered, it was in between clicks (if that makes sense)but im not completely sure.. It sounded like shocks were going..but like i said, i havent heard it for a long time now and hopefully it doesnt come back.
Old Dec 15, 2010 | 04:03 PM
That does make sense...ive also heard that it could be the sway bar links that are worn and need to be replaced.
Old Dec 15, 2010 | 07:00 PM
gaiex's Avatar
I have the back end at the top of the lenght of the KW V2 travel, and add it almost at the bottom and didn't had this vibration!
PS: Did you guys let the stock shock rebound setup of the KW V2 or did you changed it rigth away?
I have all as they came from factory, and I like it, but the rear is more harsh then the front, I'm thinking putting a bit more rebound at front.
I will also try to put less rebound at the rear to see if it gives a different result with the vibration.
Old Dec 16, 2010 | 01:05 AM
PH1L's Avatar
CLK w209 GLC43 coupe
i also have some wierd sound from the back after changing frm HnR to KW (cause my there some problem with the HnR been using it for few years)... anyway i took the car to merc and found out that the bolt on control arm is not properly tighten...
Old Dec 16, 2010 | 12:31 PM
waveterrorist's Avatar
Firemist O5 CLK55 Cab Silver 05 CLK55 Coupe Tanzanite 06 CLK500 Coupe
the dealer could not find anything relating to my 'clunk'
i think it is related to the electronic stability control
straight ahead launch yields nothing
only happens to me when moving from stop and turning the front wheels
